Need advice for project car
Discussion in 'Technical' started by auburn, Feb 19, 2004.
  1. auburn
    auburn Member
    Waterloo, Iowa
    70 Maverick
    As a new guy here to your site, I'd like to ask for some advice and help to lead me in the right direction.
    I bought a 1970 2 door Maverick. It was a project that never got finished. I'd say it's about half done the way I picked it up. Has a new / mild / 302, new c6 & 8" rear. The front end of the car was being built with all new Grabber front end parts.
    I want to build the car mostly for a weekend toy at the Drag Strip but able to run on the street if I choose once in awhile. I have 8 buddies who run the Street Class at the local strip with 70's cars... Nova's, Camero's, Malibu's, Chevelle's... no Ford's. Cut off E.T. for this class is 12.0 and slower. All of my buddies run between 12.0 and 12.80's. I'd like to be in this same time zone. I have a 302 motor that I can replace with what's currently in there. I know can run with that time.
    I hear mixed feelings about the c6 (TCI / Streetfighter) Am I wasting my time with tranny or will it work? Is the c4 a better choice?
    ~ What about the radiator? It's got a new Grabber in it. Should I replace it with a better radiator for the strip?
    ~ A-arms shocks and springs??? Should I switch to Coil Overs?
    ~ Rear end... Is the 8 inch "good enough" or should I spend the money and go with a 9" ?
    ~ What about tires on the rear? Will 8 inch street/slicks work or would 10 inch be better.
    Help is needed!!! None of my buddies can help me out without any Ford knowledge.
  2. auburn
    auburn Member
    Waterloo, Iowa
    70 Maverick
    Here's a list of what was on the car when I bought it...
    1970 maverick originally had 68,000 miles
    Engine: 302 From 1973 Torino
    Has Edelbrock 203 Cam
    Edelbrock 650 cfm Carb
    Holley Hi Flow Fuel Pump
    Holley Hi Flow oil Pump
    Clevete Bearings
    Has 2 starters, 1 old, 1 rebuilt
    New rings
    Crank Polished
    New Valves, vavle springs,seats, guides
    Tru Roller Timing Chain
    New water pump
    exhaust Manifolds from Bronco 302
    Engine and heads boiled and cleaned
    street damper, Harmonic balancer
    New alternator
    Power Brake unit added
    Front spindles from 77 Granada disc
    New rotors and calipers
    Rear brakes, shoe type
    New drums, cylinders, e-cable
    Rear end 8-1/2" 5 lug Mustang (Year?)
    New brake lines
    New TCI Streetfighter C-6 tranny Manual/auto valve body
    Needs shifter
    New Torque converter and plate
    Interior Black
    back seat newly recovered
    R1 Racing seats for front, ready for 4 point harness
    Have orignal steel bumpers both front and rear, also new fiberglass for both
    New radiator for Grabber (302)
    Tranny Cooler
    Custom Jazz fuel racing cell
    All front end parts new to include V-8 springs and A frames
    New fuel Lines
    New Tran lines
    New Hoses
    New Motor mounts
  3. Comet-73
    Comet-73 Member
    lethbridge AB Canada
    73 comet gt, 76 comet 4 door, 71 Maverick 200/I6
    The 8 inch rear end will be strong enough for the 302, treads id say the 8 will work 10 may be a tight fit in the wheel wells( im not much of the huge tires stickin out the side of the car person), C6 will work, id preffer the c4, rad is fine, shocks is really up to you either will work, it will take some work to push that 302 into the 12's personaly i would say find a 351w. I have a stroked 351w, and im still in the high 12's but i still need some more work, done to it, If you decide to go with a engine up grade you will want a 9" rear the 8" will handle it but not forever and especaily with strip racing.
    Just my .02
  4. jpollard
    jpollard Member
    Montana
    1977 Factory 302 Mav. 1970 Cougar Eliminator, 1975 302 Grabber, 1976 4door 200...and still looking
    C6 is a STRONG tranny but it will rob power that you want to the rear wheels. If you were running a big block I would go with the c6 otherwise, put a c4 in it and free up some HP.
  5. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    I know of a guy that busted up two C6s with his slightly modded 300 I6 :D . You can get into the 12s with the 302 but you`ll need to put a lot of love money and time into in you would prolly be better off getting a 351 and stroking it to 393 you can make a C4 live behind a 393 but it will prolly be cheaper with the C6
  6. Comet'ed
    Comet'ed Member
    Annapolis MD
    71Comet GT
    I disagree with this. I have a 302 with stock bottom end (cheap). With a good set of heads, cam, intake, and carb,which you will need and spend on any motor, it will easily hit mid 12's with slicks. And this is in a 3010lb Maverick.
  7. auburn
    auburn Member
    Waterloo, Iowa
    70 Maverick
    I beleave you, Comet'ed, about making a 302 run mid 12's. I have raced IMCA type Modifieds (dirt track) for 4 years and we run 302's with what your talking about
    We run on alcohol. I was thinking of switching the new motor the car came with for one of the stock car motors. I strongly beleave my stock car motor will run mid 12's.
    How much power will be robbed from the c6? I attended two Fun Ford Weekend events last year and was hearing complaints about the c4 not holding up to some of the power they were putting out.
    Infact, I think I read somewhere that FFW Event rules were going to allow them to use a Glide if they wanted to. Why would a Ford Event allow a Glide if it's a "Ford Event"? Why wouldn't they tell them to use the c6 instead?
    ~Comet-73... I know what your saying about wheels sticking out. I'm not a fan of that either. I was thinking that if I was to purchase a 9", I would shorten it up just a little bit and put a small tub in the car and tuck the rear tires in just a little bit.
  8. jeremy
    jeremy I build t5's
    Corona, Ca
    There are people with 10 second daily driven 302s, they'll do just about whatever you want.
    FYI, the grabber was just an appearance package, so the radiator and the suspension you have is oem stock.
  9. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    I think studies showed the c6 robs about 50 additional horses than a c4 does......as far a a c4 holding up????? Built it with good parts and it will handle 300-400 horses for quite sometime.
    I had trouble with my c4 when I first got the new motor, but with the right parts it seems to be doing fine!
    And 12 's are pretty easily found in a maverick with the right parts and attention to detail.
  10. elliot
    elliot Member
    Boubon MO
    You`r gonna need to love spending all that money on them good heads, intake ,cam , and carb and it will prolly take some time to build up that money so it will take love money and time :D
  11. auburn
    auburn Member
    Waterloo, Iowa
    70 Maverick
    Thanks Jeremy & maverick5946...
    Is there any market of buyers for the Radiator, A-arms and springs? If so, is it worth anything? There all new... installed but, never used on road yet. I'd like to sell the entire steering column as well (automatic on the column).
    I was looking at buying the "JEGSTER Complete Front End" from the JEG'S catalog which is priced around $2500, along with Traction Bars, Subframe Connectors, 6 point cage & Flaming River Tilt Steering Column. Going this far with it was the reason I was asking about the 8" rear end. Sounds like I might as well buy the 9".
    Jeremy, what parts were used to build your c4? Would you mind posting a list to guide me along?
  12. elliot
    elliot Member
    Boubon MO
  13. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Re: the 302
    Keep in mind that the 351W would require at least
    some clearancing of the notoriously tight shock
    towers to fit. If you are looking at running in a
    particular class at the track, get a rule book and
    build your car according to the rules.
    I would guess that you can be more competitive
    in most classes going with the 302-bored or stroked
    up to 347 and have less fire breathing competition.
    Over 347 cubes and you start running into stroked
    350 GM stuff. A 302 starting base, stroked or not, with
    GOOD heads and other bolt-ons will get you going
    in the right direction. If you are only going to drive it
    on the street once in a while, I would build a stomper
    of a 302 based car. If you were going to drive it mainly
    on the street, but wanted to hit the strip once or twice
    a year, I would go with the 351W stroked. That way
    you have a 'driveable' car for the street. You would not
    need such a radical cam with the 351 base engine to
    get the hp you would want.
    Many would suggest the elimination of the shock
    towers and going with coil overs and rack and pinion
    steering.
    Look up Stephen Moore, the NC state rep for the
    Maverick/Comet club. He runs 1/8 in his Comet GT.
    I believe he still has his shock towers in and runs
    a 347-(302 bored and stroked). He is running down
    in the mid to low 6's.
    His board name is: CometGT1974
    There are several other drag race enthusiasts here
    as well who can give you good input.
    From my knowledge, that C6 will not fit without clearance
    around the tranny hump as well. I helped a buddy try to put
    one in his car back in the 80's. His headers would not clear
    the bellhousing. I would look at the C4-good tranny and
    the previous post about it handling 300-400 hp is correct
    provided it is built with stout parts.
    Best of luck in your new project.
    Seth
  14. auburn
    auburn Member
    Waterloo, Iowa
    70 Maverick
    Seth-
    Thanks for your help... so, the "JEGSTER Complete Front End" would be a good choice? This way I could go ahead and eliminate the shock towers.
    Here's what Jeg's has listed in their catalog...
    "Stiff crossmember does not require motor plates or rigid motor mounts for reinforcement. Uses readily available, off-the-shelf header kits. 6 degrees of antidive geometry and lower performance use... Kit includes: frame, tig welded upper and lower control arms, tie rod adaptors, ball joint kit, Wilwood steering rack, new Mustang II spindles, QA-1 coil-over shocks and Aerospace Components brake kit."
  15. littleredtoy
    littleredtoy Seth
    '74 Comet GT
    Again...
    ..talk to the drag racing gurus here and elsewhere and most importantly check the rule book.
    I am pretty sure that some classes of drag racing limit the
    suspension mods that you can make. I think that Stephen
    runs in the true street class for the 1/8 and he has to be
    crafty in his suspension modifications.
    I bet eliminating those shock towers violates the rules of
    many classes.
    Seth
