Need help finding intake to carb spacer
Discussion in 'Parts Interchange' started by xnikesonmyfeetx, May 11, 2019.
  1. xnikesonmyfeetx
    xnikesonmyfeetx Member
    United States
    1976 Ford Maverick
    I have a 76 Maverick with a 250 l6. The mount that connects the intake to the carb has a broken portion where the carb bolts on. I believe its causing a vacuum leak, and I can't find one that includes the egr like mine. Any help or ideas would be appreciated. received_2228771130719369.jpeg received_396746017836660.jpeg
  2. Krazy Comet
    I'd use the non EGR spacer and toss the EGR valve.
  3. xnikesonmyfeetx
    United States
    1976 Ford Maverick
    Ok sounds good. Didnt know if it would fit.
  4. 73rustymav
    73rustymav Member
    clear lake, califorina
    First car in my life 69.5 maverick built 250 inline swap. 73 maverick RIP
    Just check the bore of the spacer adapter..... there is 2 different carb bores
  5. xnikesonmyfeetx
    United States
    1976 Ford Maverick
    How would I a about doing that? Do I measure the size of the intake side or rhe carb side of the spacer?
  6. 73rustymav
    73rustymav Member
    It's the inside diameter of the space and carb
  7. rthomas771
    Krazy Comet likes this.
