Need Help Modernizing my 1973 Maverick
Discussion in 'New Members Forum' started by BigDan, Feb 27, 2006.
  1. BigDan
    BigDan New Member
    Tulsa , Oklahoma
    1973 Ford Maverick 2 door automatic with straight six 250
    :comet: I just purchased a 1973 Maverick . It is a two door with a straight 6 250and automatic transmition. It has 66000 original miles and looks great.
    I have a problem when the car is cold it doesnt want to start unless you pump the peddal like mad before you turn the key and even then it takes several tries before it will start and keep running.
    I was wondering if I should get a carb kit and clean the carb and install the kit or just buy a new carb??? If I buy a new carb which one should I buy????? I just want it to run good I dont want to run time runs with it. I was also wondering if anyone made a throttle boddy injection conversion kit???
    Next Question
    This thing still has points , what about switching out the distributor to a pointless system???? any info would be apreciated.
    Last Question
    Does anyone have any info on putting diskbrakes on the front of my 1973 Maverick. It has four wheel drum brakes and it takes a lot of pressure to stop and a lot of room.
    I love my Maverick but I just want to give it a little upgrade:jack: :D
  2. 71gold
  3. don graham
    also check the archives on changing over to disc brakes.:)
  4. Tom Laskowski
    Tom Laskowski Member
    Bay Area,California
    (3) 71's,two V-8's and one 200 cid
  5. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    welcome to the board...:tiphat:
    All of your questions have been discussed at one or another on this board....do a search and if you cannot find what you are looking for, find the right forum and post away (y)
