Need help on recommendations for a. Radiator & fan set up
Discussion in 'Technical' started by Ford Freak, Jul 5, 2018.
  1. Ford Freak
    Ford Freak IG page the_marvelousmaverick -- follow me !
    United States, CALIFORNIA
    1972 maverick 2dr 200,c4 ,ac -sold. 1972 Mexican Maverick 302 4 spd - parted out , 1970 maverick v8 swap. 63 Galaxie 500 2dr sedan , 1984 VW Rabbit GTI
    So picking up a radiator
    Most likely going to go with a aluminum type. 3 or 4
    With electric fan
    Running a built small block
    Stick trans
    Might run a/c in the future
    Any suggestions guys
    What radiator an fan set up do you have. Or would recommend
    Also my pulley set up is a serpentine set up from March pulleys
  2. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    If you can fit it, a Taurus fan always, but I am partial.
    Ford Freak likes this.
  3. 71Mavrk
    71Mavrk Member
    Nevada
    Taurus fan with a stock radiator and Dakota Digital fan controller in front of my EFI 347. Also a serpentine belt.
    That Taurus fan really sucks in a good way.
    Micah
  4. bmcdaniel
    bmcdaniel Senile Member
    Taurus fan here, too, with the biggest Griffin aluminum cross-flow radiator I could fit in. Only have about 1/2" clearance on either side to the frame rails.
