Need help troubleshooting car won't stay running.
Discussion in 'Technical' started by 924 Mav, Jun 13, 2016.
  1. 924 Mav
    924 Mav Ed Winegar
    Pattison, Texas
    (2) 1970 Mavericks and a 1971 4dr Maverick
    I took one of my cars out for a spin. 1970 250 six cylinder. As I am driving down the road it just dies. No idiot lights or anything. I pulled over off the road and tried to restart it. It fires but as soon as I disengage starter or release the key from a full forward position it dies. When I turn key to off position and then back to on my idiot lights are on and the stay on while starting. Then as soon as I release key all goes dead again. Any ideas?
  2. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    I would guess ignition switch.
  3. Craig Selvey
    Could be lots of stuff...maybe even fuel delivery related.
  4. Krazy Comet
    No doubt switch or wiring related...
  5. rthomas771
    Had the same problem. It was the solenoid switch
  6. 924 Mav
    924 Mav Ed Winegar
    Pattison, Texas
    Does changing out the solenoid take care of this? I know where the solenoid is but when you say "solenoid switch" is that something different? Excuse my ignorance.
  7. rthomas771
    Solenoid...solenoid switch...starter solenoid...starter relay...thing the battery cable connects to that has more wires going to it (or from it). Its been called a lot of things, but yeah, replace the solenoid. If you still have a problem then it could be the ignition switch on top of the steering column or it's pigtail connector not making good connection or maybe the connection between the fuse box to firewall connector. If your wiring harness is all butchered up then it will be hard telling you where to look to trouble shoot over the internet. If you had a '74 then it could be the seatbelt interlock system.
  8. Krazy Comet
    All the solenoid is supposed to do is provide voltage to starter, jump the coil resistor and act as a terminal to connect battery to main harness which supplies power to ign switch... The fact that engine starts confirms the power is getting to ign sw and jumper is working, problem is something supplying power at ign on has failed... Since warning lights are not lit at ign on I'll bet on switch... If warning lights were on, I'd say bulkhead connector...
