need help with 3 postion switch for electric fan
Discussion in 'Technical' started by maverick7072, Aug 7, 2016.
  1. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    I bought a used perma cool 14 inch electric fan for my maverick ,I also got the adjustable thermostatic switch and control box ,I found the wiring diagram online and I need someone to help explain to me how the 3 postion switch needs to be wired!! #1 postion has the orange wire from themostatic box hooked to it #2 postion on the switch is wired to the battery the middle which is off postion is hooked to the 85 prong on the relay and then u have a ground...
    I need help explain to me how a 3 postion switch works and whatpostion do I leave it in for everything to work properly ,I'm really dunb when it comes to wiring
  2. 71gold
    I would need to see pics. of what you have.
  3. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Does their website not have a diagram?
  4. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    there is no diagram that I can find on their web-site!
    I have a adjustable thermostatic switch -control box with a 30 amp replay that plugs into the box,it has 5 wires coming out of the box one is the radiator mounted sensor the other for are orange-red-yellow and black
    I don't think the diagram I typed up on here with the 3 way postion is needed !!
    th eblack wire is ground and the yellow wire is a switched power source !! Now whats left is the red wire which has a fusable link ,I'm thinking it goes to the battery source and the orange goes to the positive wir eon the fan ,this is how I plan to wire it up ,does this sound correct
    sorry I don't have pictures and like I said the original wiring i 1st posted is wrong its for a dual fans I'm running a single
