Need help with axle removal
Discussion in 'Technical' started by gdemopesq, Sep 26, 2008.
  1. gdemopesq
    gdemopesq MOTOR CITY MAV
    Michigan
    72 Maverick 302
    Can someone give me a step by step to remove rear axle. I removed passenger rear wheel. I then got a socket and took off the 4 nuts behind the wheel studs. I thought I could pull the axle out, it wont budge, what am I doing wrong?
  2. 71gold
    you are doing great...so far.
    what has happened is the ...bearing...is stuck in the housing.
    there are a few ways to address this...
    i have put the rim back on, replace two lugnuts...(just a couple of threads).
    snatch the rim and the bearing should come loose...(y)
    ...Frank...:Handshake
  3. gdemopesq
    Michigan
    72 Maverick 302
    Sounds like a good idea. You dont have to remove the brakes or anything do you? Should I concern my self with jerking the rim so hard that the car falls of the jack stands? Do I need to disconnect a brake line or anything?
  4. 71gold
    just snap the rim...do not pull on the car...
    the backing plate will be left hanging...
    ...(y)...
  5. rthomas771
    You can use the brake drum as a slide hammer also. If this doesn't work...rent an axle puller at AutoZone or Advance and get your money back when returning the tool
  6. 71gold
    brake drum installed backwards is another great way...:thumbs2:
    just leave the nuts loose...
    ...:tiphat:...
  7. 71gold
    ...we got this axle out yet??? :huh:
    Frank...:Handshake
  8. gdemopesq
    Michigan
    72 Maverick 302
    I got it out. Got new bearings and seals on. Got the 3.55 posi in. Now I am just breaking it in. Thanks, the reverse brake drum worked well.
  9. 72MAVGRABHER
    Roanoke, Va.
    Doesn't anyone use slide hammers anymore? :biglaugh:
    Guess not everyone has one laying around like me... :rolleyes:
