need help with shocks!?
Discussion in 'Technical' started by jjl, Mar 20, 2014.
  1. jjl
    jjl Member
    prince albert saskatchewan
    1973 ford maverick ,2006 pontiac grand prix, 1994 cadillac deville, 1967 gmc c10(project).
    Hey guys my rear shocks are basicly gone on my 73 maverick, does anybody know if 68-70 mustang shocks would work? I want to put some coilovers on the car but dont know what to go with! Also i am tajing apart some spindals and will post some pictures in a day or two, the guy i baught my car from said they would fit but i just need some expert opinions!!:):bananaman thanks againguys!!
  2. Dave B
    You need Maverick shocks for the back, Mustang ones are different. They are easy to find.
  3. mav1970
    Maybe not in Saskatchewan :)
  4. Dave B
    With the internet, everything is easy.
  5. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    If your car is basically stock I would not use coil overs,they are mainly for racing.
  6. Craig Selvey
    Coil over's can cause the same damage as air shocks.
  7. mav1970
    To add true coil over springs, you would have to get rid of your leaf springs, add a 3 link or 4 link system along with new cross members - what some call coil over shocks are only stock shocks with the helper coils built in and, as long as you keep your stock leaf springs, you really don't need more springs back there :)
  8. maveruss1
    maveruss1 '70 5.0 C-4
    Moreno Valley, Ca.
    1970 2dr.Maverick, 2005 Mustang
    I installed Nissan truck KYBs on my 70 Mav and they fit and ride awesome. I still have the boxes if you need the part#. The FRONT are KYB (Gas-A-Just) part# KG4517. The REAR are KYB (Gas-A-Just) part# KG5447.
  9. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    The best shocks that ate available for.the maverick are the Q series ftom Ridetech
    if you make a tri4 link, 3 link or torque arm in the rear for a coil over again..ridetech has a true coil over.
    next best wouldd be a hybrid coilover by Viking Performance
  10. Mel Moeller
    Mel Moeller Maverick Moe
    Twin Falls Idaho
    1971 Ford Maverick, Two 1973 Mavericks, 1974 Mercury Comet
    Does anyone know what shocks that I would need with a 8.8 Explorer rear end?
  11. rlbriggs7212
    rlbriggs7212 Member
    Grass Valley
    1972 Maverick 64 Fairlane 52 Henry J
    Part #'s would be nice.
    RLB
  12. Bryant
    it depends on what spring ubolt plates you use. if you use the maverick ones then use standard maverick shocks. you will have to slot the holes in the maverick plates for the bigger axle tube ubolts to fit. if you the explorer plates you will need to get shocks with eyes on both ends that are the right lenght. lots of applications in that configuration so just figuring length is the tricky part.
  13. Mel Moeller
    Twin Falls Idaho
    Thanks Bryant
  14. maveruss1
    Moreno Valley, Ca.
    Here is the KYB boxes with part#s for front and rear shocks. For everyone, the rear ones are unknown but these Nissan truck ones fit perfect and ride nice. Fronts are #KG4517 the rears are part# KG5447 (KYB Gas-A-Just). These are the best KYB Shocks of this brand for Mavericks.
  15. dyent
    dyent Member
    vancouver bc
    I have a set of KG4517's for sale if anyone is interested?
