need length of auto trans tip stick.help
Discussion in 'General Maverick/Comet' started by loopydog, Nov 29, 2003.
  1. loopydog
    loopydog Member
    ontario
    762d@774d
    when i got the car did not have one and now i found one at work and it fits but i need to know . the real length from the end to the start of the handle . and from the end to the add and full mark. that would help alot thanks.
  2. 71gold
    :rolleyes: what motor and what year. thanks...frank...
  3. loopydog
    loopydog Member
    ontario
    762d@774d
    THANKS
    77 MAV 250 MOTOR THANKS:bananaman :p :bananaman
  4. 71gold
    let me check with kelly, he has the 250 i pulled out of my 73'...frank...:bananaman :bananaman
  5. Kelly Evans
    Kelly Evans Member
    Centerville GA
    1969 1/2 Maverick
    Auto Trans Dip Stick
    Frank can tell you what transmission this is but it is an automatic hooked to a 250 so assuming there is only one this is the Information off the dip stick.
    Part # DOOP-7A020-? The last one is a B I think but it could be a D or an 8 the way it is stamped I am not sure. Where the handle attached to the stick part it is rivited with two rivits . It is from the TOP of the cap to the end of the stick is 20 1/2 inches overall length from tip to top of bend where your finger goes to pull it out is 23 inches. There is a crimp that the cap that seals over the dipstick tube rests on which is 19 3/4 inches from the point. The add mark is approx 1 5/8 inches up from the point and the full mark is approx 2 inches. Hope this helps. Let me know if you need anything else. Kelly
  6. 71gold
    the trans is a 73' c4...frank...
