need numbers for a 74-77 Maverick rear end
Discussion in 'General Maverick/Comet' started by Joed, Jun 22, 2007.
  1. Joed
    Joed Member
    El Paso, Texas
    1963 Comet S-22 Conv.
    I am about ready to go buy a 74-78 maverick rear end for my 63 comet project and want to make sure I get what I want. Do any of you guys know the numbers for those years. I am looking for a 5 lug.
    Thanks,
    Joe
    Joedaubach (a) yahoo.com replace (a) with @
  2. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Mavericks came with 2.79 or 3.00 open 8" rears, except the 69 1/2 and a few 70's that have a 7.5 rear, which is always 4 lug. 8" rears were made in both 4 and 5 lug.
  3. Joed
    Joed Member
    El Paso, Texas
    When looking at this rear end how can I decode the cast number to make sure I am getting a 74-78 as I have been told this will be a direct bolt in with my 63 comet.
    Thanks,
    Joe
  4. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    i have a 75 8 inch , local pick up only
  5. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Someone probably told you to look for the 74-77 rear because they were all 5 lug at that point.
    Before 73 or 74, they were either 4 or 5 lugs depending on drivetrain. However, they will bolt in anywhere the later rears will bolt in. They were all the same when it comes to mounts and dimensions.
    As for numbers... I don't know what they would be.
    You would need to know exactly what measurements you need, and measure the rear in question and see how it stacks up.
    If you don't know anything about the part you are buying, I would suggest you find a rear that is still in the car and watch it get pulled out.
    That way you know what you are getting.
  6. don graham
    i don't think the number will help you very much. i believe the rear ends have tags on one of the bolts. most of them are probably missing. i would just make sure it comes out of a maverick or comet. as long as it's a 5 bolt it should fit.
