need some advice here
Discussion in 'General Maverick/Comet' started by adam 72, Oct 5, 2012.
  1. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    I've been looking at some rebuild kits. They have been priced from $400 (ebay) to $1200 (classic inlines). The classic inlines seems pricey but they have a good number of things I was planning on putting anyways, such as: the larger hydraulic cam, flat top pistons, dual roller timing chain, and so on. SO think it'd be better to dish out the large amount of money and know what I'm getting, or order what I want from classic inlines and figure out where to get the other parts for the rebuild?
    Same thing for the cylinder head. I was thinking about rebuilding that and throwing in components to run unleaded gas, but now I'm thinking of finding a later head and just rebuilding that. What do you guys think?
    Thanks!
  2. Craig Selvey
    What are your goals? Why are you rebuilding your motor? What size motor are we talking about?
  3. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    Guess I should have mentioned it's a 200 inline
  4. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    I want a little more power. Not a power house but just something. Later I want a dual outlet header and a larger exhaust. Want somewhere around 150hp. I like the 6 because I can work on it and like the idea of at least 20mpg after a mild performance build
  5. 71gold
    is a 302 an option...
    the money you spend on that 200 will be thrown away for what you want...:bouncy:
  6. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    Well I want the 200. I don't want to bother with an engine swap until I learn more and have another car. And its my daily driver do I want decent mileage
  7. 71gold
    are you going to pull/rebuild the 200?
  8. 71gold
    what rear gear do you have now?
  9. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    Yeah. I was thinking about having a shop rebuild it
  10. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    It has the 4 lug stock rear end. My grandpa has a 5 lug rear end waiting for my car. Not sure on the specs. I think it's geared more towards a manual transmission
  11. 71gold
    if it's a stock Mav/Comet, it's a 2:79 or 3:00.
    are you rebuilding the transmission at this time also to handle the extra power?
  12. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    Well I should've thought about that soon. It was rebuild over summer. I imagine its for stock power.
  13. 71gold
    are you pulling the motor and taking it to them? the reason for all these questions is...trying to get you a budget set for this build.
    you will need a new/reconditioned radiator for the new motor also...need to flush heater core.
  14. 71gold
    are you doing the 5 lug swap on the front at this time also?
  15. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    I was planning on upgrading the radiator anyways. And maybe pulling it and taking it to them. That depends if I fond a way to pull it and put it in without too much of a problem
