need strut tower help
Discussion in 'Technical' started by momaverick73, Aug 19, 2008.
  1. momaverick73
    momaverick73 Member
    joplin mo
    75 ford maverick 2 door 99 ford taurus SHO
    I have this mav with a mustang k member someone welded in, looks ok, but needs finished. any helpful ideas would be great. I hope these pics work, Im not very computer savvy...:confused:
  2. Bryant
    first you will need to brace up the strut mounts up top where they tie into those uper bars. also they should have some sort of adjustment for caster and camber. then put a killer motor and all related bad a$$ acessories make it all work and enjoy.
  3. bmcdaniel
    You'd probably get some responses if you asked a specific question. What do you want to do?
  4. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I don't think those strut mounts are going to hold up.
    They have a great deal of leverage on that one weld...
    They need towers.
  5. Mavman72
    Definitely replace those upper strut mounts.As stated put in something you can adjust caster and camber with.What ever you put there make sure it is boxed/gusseted for rigidity/strength whats there now... one good wheelie and its all over.good luck.
