Need Throttle Cable Length
Discussion in 'Technical' started by kukm66, Apr 13, 2010.
  1. kukm66
    kukm66 Member
    Phoenix
    1972 Grabber, 1964 Falcon Futura Convertible, 1964 Ranchero
    Anyone that has a throttle cable from a Maverick/Comet, would you please measure very accurately the total length from tip to tip and report back. I took a cable assembly off of a Fairmont at the JY and tried to install it into a 64 Falcon and the cable is a good 1 1/2" too long or more. I am wondering if there were different length. I can see no way to adjust the length other than cut and reinstall the ball.
  2. Craig Selvey
    How long do you need?
  3. kukm66
    kukm66 Member
    Phoenix
    That is what I am trying to find out. If I can get the stock length from a Maverick and compare it to the one I have from the Fairmont, I might be able to just swap it out if it is shorter.
  4. rthomas771
    It would have been more helpful if we knew if you're were working on a 6 cyl or V8 and the year and length of the Fairmont cable on hand.
    Here is a list of what size cables were used in the 73-79 Mustang, Granada, Pinto, Maverick and Fairmont.
    http://1bad6t.com/Extra2/CableLength.gif
  5. kukm66
    kukm66 Member
    Phoenix
    This was for a 200 CI setup. From the looks of the table, my suspicions are now confirmed. I will check mine tomorrow and measure. Right now it is installed.
