neutral safety switch
Discussion in 'Transmissions' started by katrider, Sep 6, 2007.
  1. katrider
    katrider New Member
    Hi all..we are switching out a column shifter (C-4) for a B&M floor mount shifter, and we are wondering where the original neutral safety switch was located? Was it up on the column? Or the transmission? Thanks for any help...:huh:
  2. don graham
    mine was on the tranny, but i believe some years are on the column if i remember right. i'm sure someone else is more familiar.:)
  3. Craig Selvey
    If the original car was a:
    Column shift = on the column
    Floor Shift = on the tranny
  4. don graham
    thanks craig. i didn't know that. i just thought it had to do with the year. learn something new every day. :)
  5. katrider
    katrider New Member
    OK...so the switch is on the column. That means if the column was in the neutral or park position when it was disabled, then the safety switch should be closed...that's what we'll look for at the pig tail connection. Thanks.
  6. Craig Selvey
    That is correct.
  7. PaulS
    There is a tranny mounted neutral and back-up switch that can be used if you are going to an aftermarket shifter. you just have to plug it into the harness and adjust it. It fits where the shifter linkage goes through the tranny case. It is held in place with two 1/4" bolts. The holes are slotted for adjustment purposes.
  8. seafish006
    seafish006 New Member
    pa
    1973 ford maverick grabber
    dose any one hsve a photo of a neutral safety back up light switich for a 1973 ford maverick?
    thank you
  9. Bob Wiken
    Fayetteville, Arkansas
    here ya go
  10. Bob Wiken
    the two screws that hold the switch on are very small and one is Very hard to get out. It's hard for this old fart to lie upside down onm tjhe floor and work
    LOL
  11. PaulS
    Depending on the car it can be at the base of the steering column or on the transmission at the manual lever. As far as I know the Mavericks and Comets had it at the base of the column with the ignition switch (switch on the column). If you have a 69 1/2 then I am not sure if it is on the shifter or transmission.
