New car and a few things are disconnected
Discussion in 'Technical' started by GavinM, May 13, 2016.
  1. GavinM
    GavinM Member
    Goodyear AZ
    1977 Maverick v8 302
    So just got my car home today and started taking a peak around under the hood. Here are some pictures of things thst are disconnected/cut
    These are on the front right(facing the engine bay) side 20160513_182928.jpg 20160513_182933.jpg
    Both of these red hoses are cut. They go into the firewall on the passenger side 20160513_183012.jpg
    And this is just the hose from the thermostat with a bad kink in it(not sure if that could cause my heat problem)
    Any help figuring out whats what would be awesome
  2. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    The red hoses go to the heater, it's probably disconnected because of a core leak.
    The others appear to be a/c lines. Looks like the compressor is missing.
  3. GavinM
    GavinM Member
    Goodyear AZ
    Okay thank you for the info. Heres another picture if you can spot anything else out of place or missing 00Z0Z_6QqaFPh2ACS_600x450.jpg
  4. mojo
    Shock tower braces missing.
  5. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    Looks like the radiator hose is a little long, cut a half inch from the end and re install. The kink should become undone. If it's still there take a little more off and reinstall.
  6. Maverocket
    Northwest
    The compressor is there, but mojo' right on the tower braces.
  7. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    The first two pictures look like a power steering line.
  8. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    The passenger side valve cover is missing the pcv valve, or the connector that hooks to the air cleaner.
  9. GavinM
    GavinM Member
    Goodyear AZ
    Just added them back on today. Not sure why he removed them
    Cut hose still has a kink but im going to get a new hose for it
    Found out the power steering is completely unhooked the hose at the bottom of the pump up is cut and capped and the pump is empty! on the to do list for next week, today we changed the oil and boy was that oil bad
    Good news is my neighbor dropped off a bunch of mustang parts today for free!
  10. GavinM
    GavinM Member
    Goodyear AZ
    Anymore info on this? could this also cause any sort of bad air smell to come from the car?
  11. yellow75
    Tillamook Oregon
    There is a hose that goes from the white plastic jug cannister that is located under the passengers side hood hinge and goes to the air cleaner. This is what the gas tank vent tube goes to, you may get a gassy smell from that area
