New electric fan killing battery
Discussion in 'General Maverick/Comet' started by BigDog41364, Jun 27, 2015.
  1. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    I installed a new electric fan today (my last project before the trip to the national round up) I let it run in the pole barn for about 45 min then took it for a 5 mi ride to see how the temp stayed, came back shut it off and it would not turn over. jumped it and it started right back up. The battery is new, i have a 60A alternator. I don't know how old the voltage regulator is. Is the alternator too small? if so what size should i install?
    16in flexlite fan
    Deral fan control
  2. Ryan Whiteside
    Ryan Whiteside MCCI SC State Rep
    Upstate, South Carolina
    1969.5 Ford Maverick 302
    Are all the connections secure? Just went through this same problem with my electric fan and it was a loose wire causing the battery to drain.
  3. mojo
    U may have to step up to more capacity alt. I run the Flex-a-Lite and 130a alt. It seems like 60 should work, if ur not running anything else - but may not be enough. I run 130a but I have AC and stero amp. I never have any issues w/ batt. drain.
  4. 71gold
    check the voltage at idle w/fan on. you may have let is run too long at too low of an idle.
    Krazy Comet, mojo and rthomas771 like this.
  5. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    Can I check amperage out put with a multi meter? If so, how
  6. mojo
    Most muti's don't have over 10amp capacit y- I don't think that wud work too well. I wud use a automotive type tester and hook it in series w/ whatever ur testing. Make sure neither lead shorts to ground.
    I agree w/ Frank, u may have let it idle to long w/ low alt. output and drain the battery.
  7. mav1970
    Do you run any under drive pulleys ?
  8. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    I don't know what under drive pulleys are
  9. mav1970
    Then you are OK in that department :cheers:
    Under drive pulleys are a different from stock size matched set of pulleys - we used them on stock cars to slow the water pump and alternator down as we were running between 4500 and 6500 RPM every lap but running the engine slow during cautions, the water pump and alt would turn too slow causing heat & charging problems
  10. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    ah gotcha :tiphat:
  11. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    Did a voltage test after work today.
    13.15v sitting
    dropped to 12.95v after starting
    dropped to 12.70v when fan kicked on
    higher RPM,s voltage dropped about .5V
    installed new alternator witch i already had same results. im thinking voltage regulator?
  12. 71gold
    sounds like a bad cell in batt...has volts but no cranking amps...:yup:
  13. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    Shouldn't there be around 14.5 volts when the motor is running? That's why I'm thinking voltage regulator
    . The battery is only 6 weeks old
  14. Krazy Comet
    Assuming a cool alternator yes, but as temps climb voltage will be less, I'm uncomfortable with under 13.8v... But if you turn on high beams, heater blower on max, windshield wipers on high, new fan etc if it holds above 13.5v it should be OK... Problem is when idling it probably won't hold 13.5v, so is gradually discharging...
    Fixes are get a newer alternator that has increased charging capability, or do the simple thing and add 150-200 RPMs to idle speed...
  15. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    When I increased RPM voltage went down
