New Intake, Need to know what all goes in these holes
Discussion in 'Technical' started by maverick656, Jul 8, 2018.
  1. maverick656
    maverick656 Member
    Washington Pa
    1975 Ford Maverick
    Its been awhile since I've posted on here. I'm wondering what goes in these holes on my intake. I don't have the original intake anymore, so I don't have any referance. It's carbed obviously, and my heater core will not be used more than likely, so how would I bypass that as well. First pic is back of Intake and the last is the Front. Thanks! 20180708_214503.jpg 20180708_211936.jpg 20180708_214503.jpg 20180708_211936.jpg 20180708_214509.jpg
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    The one behind the carb is for the vacuum tree, the little one behind the distributor is for the coolant Temp sensor or Temp gauge fitting, and the one on the side of the distributor is for the heater hose. Plug the ones that will not be used.
  3. maverick656
    maverick656 Member
    Washington Pa
    1975 Ford Maverick
    As far as plugging them, can you get plugs that are flush with the intake? I don't really want to throw a bolt in there if there is another way. also, can you run no vacuum? I don't have any power brakes or anything fancy, the car is mainly a weekend driver
  4. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Bolts would not work. Use pipe plugs. They are designed for it. They have either allen or 3/8" square drive sockets.
  5. Craig Selvey
    You HAVE to run a vacuum. Many things on the motor and the car run off of vacuum.
    Crazy Larry likes this.
  6. ADOR
    ADOR Member
    Northeast Louisiana
    1972 Comet Gt
    On your plugs try to use the brass ones. In the future if you have to take one out and it's stuck. It's a lot easier to drill out than steel. They will be pipe thread so you can get any kind of regular or low profile plug you want. You may have to get a combo from the parts store and hardware store to get everything you need.
    maverick656 likes this.
  7. tbirdz12
    tbirdz12 Member
    Sun Lakes, Az
    69.5 Mav
    ... pipe plugs are tapered.... bolts aren't..
  8. maverick656
    maverick656 Member
    Washington Pa
    1975 Ford Maverick
    Craig, What would run off the vacuum other than the brakes and emission equipment? I take it most of the vacuum is created from the intake, so having the tree on the back of the intake would be the main source of vacuum correct?
  9. Craig Selvey
    The transmission shifts off of vacuum
  10. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Also the vents and heater valve if your car has A/C.
  11. baddad457
    Use brass plugs and antisieze or Teflon pipe dope on the threads.
  12. maverick656
    maverick656 Member
    Washington Pa
    1975 Ford Maverick
    So from what I'm Gathering I need to put a ported vacuum switch on the back of the intake for the tranny at the least. correct? I'll put a ported vacuum switch on the intake, and take the line from the trans and hook it to there
  13. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Not a ported vacuum switch. A vacuum tree.
  14. maverick656
    maverick656 Member
    Washington Pa
    1975 Ford Maverick
    What's the difference? When I search for vacuum tree I get no results
  15. maverick656
    maverick656 Member
    Washington Pa
    1975 Ford Maverick
    Should be a 3/8 pipe thread as well correct?
