new to fords
Discussion in 'New Members Forum' started by 37788mav, Apr 30, 2013.
  1. 37788mav
    37788mav Member
    south carolina
    1970 maverick,1959 vw
    had chevrolets all my life.bought a ford maverick with 250 6cyl (good on gas and my wallet) for my son.it has a carter RBS carb on it.put new wires,plugs,points....ect.rebuilt carb. but cant get it to idle.checked all vacume lines and every thing i can think of but still no idle.if i barely crack the throttle it misses anything above that it runs smooth.as soon as i let it go it stalls.am i missing something about these cars?
  2. mav1970
  3. scooper77515
    Welcome to the board!
    I would start at 1) who rebuilt the carb? Might be better off with a new one. That thing was 40 years old before it was "rebuilt".
    2) vacuum leak, somewhere.
  4. 37788mav
    37788mav Member
    south carolina
    i rebuilt the carb.not ne to rebuilding carbs.man i have checked and checked for vacume leaks.that was my first thought.those little carbs aint cheap!thanks any way.will keep working on it.
  5. scooper77515
    Sorry to offend, but my first gut feeling is "some guy" rebuilt the carb before you got it.
    That is almost always a bad thing.
  6. don graham
    Welcome to the board.:Welcome:
  7. junrai
    junrai Member
    rancho cordova ca
    check your fuel filter? I had a truck that would run great with my foot on the gas but as soon as I let off it would die. checked everything over and over again EXCEPT the fuel filter.
    my filter was bone dry when you let off the gas and when you revved the engine a little you could just barely see a trickle go through the filter. (guess thats why I got such good gas mileage from a 390) changed the filter and it ran great all the time. used a little more gas but would stay running lol
  8. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    :Welcome:to the site!!!!!
  9. Red1972Grabber
    Northern California
    Welcome from Northern California:chirp:
  10. MistaVista
    MistaVista Member
    Sun City, CA
    1974 Maverick 1970 Falcon Futura 4 dr.
    :Welcome: from so. cal.
  11. injectedmav
    injectedmav Member
    Georgia
    Welcome from GA!:tiphat:
  12. Krazy Comet
    I've seen various carbs over the years with this condition, almost always due to a idle passage blocked with dirt or corrosion... You'll need to pull it apart again and be absoultly certain those passages are open...
    BTW Welcome...
  13. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    Welcome to the site,make sure the butterfly shaft is tight,even a small amount of play will cause your problem.
  14. 37788mav
    37788mav Member
    south carolina
    sry for delay.catching on to how the site works.will check every thing agin
