New to group, Tremec Transmission question
Discussion in 'New Members Forum' started by broncoindian, Feb 12, 2010.
  1. broncoindian
    broncoindian Member
    Texas
    70 Maverick
    Who has installed a Tremec transmision in their car? What issues did you run into, (like did you have to trim the tunnel, did you have header issues, were you able to use a cable clutch?)?
    Thanks
  2. mav1970
    :Welcome: to the forum from Northeast Pennsylvania
    Sorry, I'm no help to you since I'm just running a plain ol' toploader :)
  3. Moneymaker 1
    Panama City Florida
    Welcome from Florida!
    No help from me...just getting started, sorry
    Paul S...he is the tranny guy in here he may have answers for ya.
  4. broncoindian
    broncoindian Member
    Texas
    70 Maverick
    Well, I guess we will find out, I am going to attempt it. I will take picture and keep you informed as I get along. I am pretty sure I will have to fabricate a new tunnel so I have purchased the metal and will start forming this weekend.
  5. mav1970
    Is your Maverick a 1970? The 70 has a small tunnel anyway and I had to do some "adjusting" just to get my toploader to fit in it. The tunnels in 71 and later are larger but you're replacing it anyway.
    Save some pictures for us :thumbs2:
  6. broncoindian
    broncoindian Member
    Texas
    70 Maverick
    yes it is a 1970.
  7. mav1970
    Well, you're dealing with the smallest tunnel a Maverick had. I know nothing of the size of a Tremec but you might be right in replacing it then.
    You might want to look at putting some sort of bracing in under the floor between the rockers. The original formed tunnel is a large piece of the strength built into the floor boards. Now you'll be replacing it with something that will only screw into place. :tiphat:
  8. broncoindian
    broncoindian Member
    Texas
    70 Maverick
    Yes I plan on bracing it. I also will be welding the new metal in with the only screws used for a couple of trap doors.
  9. mav1970
    Good thinking :bouncy:
    The only reason that I mentioned it was I only cut 2 inch wide slots through my floor boards for my 2 x 2 sub frame connectors and you couldn'nt believe the flex in the floor from just that. I couldn't imagine having the entire tunnel out. :cry:
  10. ke4zaj
    ke4zaj Member
    douglasville ga
    1970 ford maverick
    :Welcome:from douglsville ga
  11. Mercurycruizers
    Venetia, PA
    :Welcome:to the board...
