Newbie Motor Mount Question
Discussion in 'Parts Interchange' started by 691/2MAV, Jun 26, 2002.
  1. 691/2MAV
    691/2MAV Member
    Colorado Springs
    1969 1/2 Maverick
    I am new to this group and new to Mavericks, but not new to restoring cars. I have a 69.5 Maverick that I want to put a 302 in. I know where there is a set of motor and frame mounts for a 65 Falcon. Will these work? Or does anyone here on the board have a set to sell or know where I can get the right ones?
    Thanks
  2. K. Merring
    K. Merring Regular
    Easton,Pa.
    73 Comet GT
    Mounts will not fit.
  3. 691/2MAV
    691/2MAV Member
    Colorado Springs
    1969 1/2 Maverick
    Bummer
    Thanks for the reply. I am still learning about what will and will not interchange.
  4. K. Merring
    K. Merring Regular
    Easton,Pa.
    73 Comet GT
    69-73 Mustang and Granada/Monarch lower and upper control arms, springs and related hardware, shocks all fit. There can be some differences in ball joint taper on some cars.
    The Mustang spindles may not directly bolt up.
    For disc brake conversion, use the later Mav/Comet disc spindles or the Granada/Monarch units. The calipers are all the same. A good place to see what will interchange is the Whitney or other catalogs on some of these parts. Look at the part numbers that are the same between cars.
    On the body, few parts will inter change except things like door hindges, heater motors and the like.
    Power brake cylinder and control valve will be the same up thru 77. if you need 69 brake hoses, they will be hard to find.
    302 engine /trans will all interchange. The 8" rear is the narrowest of all the cars so will only take a wider unit depending on you clearence needs. 9" Lincoln Versailles disc brake rear will go in with attendant, spring and its mounting, alterations.
    Your car, I think has 9" drum brakes. You can upgrade to 10" 5 lug drum/spindle in the front but need to decide what to do about the rear 4 lug small brakes. The front to back bias will be upset unless there is attention given to adjusting the pressures. More than you ask for but hope it helps you get a handle on the situation.
    Ken
  5. Mavericknutt
    Mavericknutt member
    BoisdArc mo.
    1971 maverick 2dr m2 front end coil over ladder bar rear suspension 472 ci. C-6 tranny
    i have a set of mounts block and frame and a v8 crossmember i would be happy to sell.
    robert
  6. nickriede
    nickriede speed freak
    ottumwa, ia
    73 maverick 2dr, MII front suspension
    im putting a 302 in a 250 I6 maverick and was wondering if my 302 block mounts will bolt onto my straight six frame mounts? dose anybody know? if not i will need the frame mounts.
  7. don graham
    i just got 2 motor mounts for a 302 in a 71 maverick at napa. they were less than $30 for both. don't know about the frame mounts but you could ask them.
  8. Mavaholic
    No they wont. You need the 302 frame mounts.
  9. Maverickgrrl
    Maverickgrrl Member
    Des Moines, Washington
    And unfortunately, you need to get them from a Maverick or Comet... Nothing else will fit. Don't forget you'll ALSO need the Tranny mount too.
  10. nickriede
    ottumwa, ia
    i got the tranny mount it bolts right on its from a 67 mustang with a c4.
  11. nickriede
    ottumwa, ia
    dose any body have the frame mounts and crossmember for a 302 maverick that they want to sell for under $50. im getting ready to swap motors and i need these parts. if nobody has them, dose ne body know if i could buy them at orielys or napa or places like that?
