No reverse !!!! WTH!
Discussion in 'Cosmetic' started by Mav_Max1972, Apr 12, 2019.
Tags:
  1. Mav_Max1972
    Mav_Max1972 Member
    California
    1972 Ford Maverick
    Just put in a new steering colum for my 1972 Ford Maverick 6 cylinder automatic trans and now my car won’t go in reverse but it does go to all other gears can some one help me out ... thanks to all my Mavericans lol
  2. 71gold
    it goes to park but no reverse?
  3. Mav_Max1972
    Mav_Max1972 Member
    California
    1972 Ford Maverick
    Yes all gears except reverse and before that it was working great
  4. Krazy Comet
    Unless the linkage is misadjusted causing a a between gears problem, there is no reason swapping column should cause loss of reverse or any other gear.
    71gold likes this.
  5. yellow75
    Tillamook Oregon
    I would jack car up and disconnect linkage at transmission and manually shift it through the gears by hand, it should click into the gears and you should be able to feel it. Put it in reverse on transmission arms and put shifter arm on column in reverse and hook linkage arm back on transmission. You may have to make some adjustments to make it go correctly. As Krazy Comet has said no reason to lose any gears from a column swap
    Krazy Comet likes this.
  6. Mav_Max1972
    Mav_Max1972 Member
    California
    1972 Ford Maverick
    Is there any electrical component connect to the steering colum that can effect the trans ? And the guy I bought it from said it’s out of a 74 now but when at first he said it was out of a 72 and it fit just right. Thanks Krazy Comet and Yellow75. And if you Mavericans have any other ideas please let me know thanks
  7. yellow75
    Tillamook Oregon
    Nothing electrical that effects the gears just a neutral safety switch and reverse back up lights, I cant state for sure that there is no difference in years of columns that effect the gear selection
  8. Mav_Max1972
    Mav_Max1972 Member
    California
    1972 Ford Maverick
    Thanks for the help guys I’ll keep you updated on the situation thanks again been a help
  9. Mav_Max1972
    Mav_Max1972 Member
    California
    1972 Ford Maverick
    Hey guy no luck idk what’s going on but I have no reverse what else can it be I also changed the speedometer wire can that have an effect on it
  10. 71gold
    ...:disagree:...
  11. 71gold
    long shot...fluid level OK?
    Mav_Max1972 likes this.
  12. Mav_Max1972
    Mav_Max1972 Member
    California
    1972 Ford Maverick
    Thanks i was going to change trans oil
  13. 71gold
    how many miles on transmission?
  14. William623
    William623 Member
    Orlando
    1973 ford maverick grabber
    So you did try disconnecting the linkage and shifting it by hand and it did not work? Also the speedometer will not affect it.
  15. Krazy Comet
    In 50+ years, I've never seen any transmission have forward gears and not reverse(or the opposite) and fluid be the problem. If it's low enough not to have reverse, you ain't moving forward either('less maybe your buddy, wife, etc is pushing). There is a point in fluid level where trans may try to move forward and not move backwards, but it'll slip like crazy in the forward gears.
    As already suggested check the transmission detents, if you can't find reverse, it ain't there.
