Non Power Disc Brakes
Discussion in 'General Maverick/Comet' started by mustangturbo50, Apr 1, 2008.
  1. mustangturbo50
    mustangturbo50 Member
    bettendorf, ia
    ok im going with non power disc brakes in the front, any suggestions on what master cylinder to use? i dont think my drum brake master cylinder is gonna do the trick?
  2. 19BlacK77
    19BlacK77 Member
    How about a non power disk brake master cylinder off of a maverick. (y)
  3. mustangturbo50
    bettendorf, ia
    yeah>>>>
    lol yeah........... that would make sense huh lo. so 74 was the only year for that right?
  4. 71gold
    this is the one i'm using...also kept it with my ...rear disc. brakes...using stock porp. valve...:yup:
    ...:cool:...
  5. 19BlacK77
    19BlacK77 Member
    Nope. My 77 dosent have power brakes, so I would say that they came on some mavericks from 74-77.
  6. Mavaholic
    I've been using my stock 72 master cylinder on front disc for years. Works great.
  7. CaptainComet
    I bought a brand new 77 Mav non-power disc brake master cylinder from (I think) Advance Auto Parts for somewhere around $30. The brake pedal will ride high if you don't shorten the pushrod.
    I would also get a later combination valve that is suited to disc brakes. The earlier one keeps 10 psi of drag on drum brakes, later ones only keep 2 psi of line pressure on disc brakes. I went to a Wilwood adjustable prop valve, but having done that, it seems like overkill. A factory combo valve would probably be fine.
  8. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    i also use my stock mc with my disc brakes with no problem
  9. Jamie Miles
    Using a stock '73 all drum master cylinder with front discs here also.
  10. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    yup...me 6 :thumbs2:
  11. Mavaholic
    What do you base this on? I have heard this before and have never been able to verify it. I have taken apart a proportioning valve and there are no check valves to maintain any pressure. Considering the total square inches of drum brakes, that would be a lot of static pressure.
  12. 72CometGT
    72CometGT Member
    Atlanta, GA
    Green 72 Comet GT
    I did the front manual disc conversion and used a 74 Maverick MS and my pedal does ride about 1 1/2" higher than my clutch pedal. I've gotten used to it, but it'd be nice to fix it. If I wanted to shorten it I guess I'd have to cut the end attached to the MS...
    When I grabbed the Granada spindles I got its prop valve too and I haven't had any stopping issues, the back tires just barely break loose under really hard braking so I think the distribution is right.
  13. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    I bought an adjustable M/C pushrod so I could make my clutch and brake pedals the exact same height ...
  14. 71gold
    Earl bought one for his car and i made me one like it...:yup:
    ...:bouncy:...
  15. 72CometGT
    72CometGT Member
    Atlanta, GA
    Green 72 Comet GT
    Got any pictures of it? Does the stock one just pop out of the MS if you pull hard enough?
