Oil and temp sensors and teflon tape
Discussion in 'General Maverick/Comet' started by smegnl, Sep 5, 2020.
  1. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    I got a set of gauges and new sensors. The directions said to use teflon tape around the sensors. Aren't the sensors electrical and need grounding through the block? Won't the Teflon tape interfere?
  2. rickyracer
    rickyracer Member
    Central Nevada
    66 Stang, 68 Cougar, 72 Comet GT
    Yep sure will, use a little pipe sealer goop.
  3. Krazy Comet
    I've never had a problem using teflon tape.
    Threads will cut through it, grounding won't be a issue.
    71gold and BBMS18 like this.
  4. stumanchu
    stumanchu Stuart
    Portland, OR
    2x on teflon. I never put more than 3 wraps, unless 3 wraps leak. I would think the coolant itself would help ground it, but I never thought about it that far.
  5. bmcdaniel
    I'm not big on Teflon tape my self. When used on tapered fittings it can break off in little strands that go places you don't want it to.
  6. rthomas771
    I always put sensors on right out of the box without any type of sealer. Pipe threads are tapered and self-seal
    71gold and jasonwthompson like this.
