Oil filter and manifold rubbing on V8 swap
Discussion in 'General Maverick/Comet' started by Kylekfr1, Jul 29, 2016.
  1. Kylekfr1
    Kylekfr1 Member
    Maryland
    1974 ford maverick
    I'm currently doing the v8 swap on a 74. Dropping in the engine, transmission combo I noticed the exhaust manifold touching the steering box and oil filter on the fender. Just wondering if anyone has had the same issue and their solution.
  2. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    You need a Maverick specific exhaust manifold, they exit about 3 inches lower. IMG_0360.JPG
  3. JoeB
    JoeB Member
    Stowe, PA
    71 Maverick, 72 Comet GT
    Jeep 4.oL oil filter will be a little shorter...
  4. 71gold
    do you have the correct motor mount stands and mounts? and if so, are they installed on the correct sides.
    Crazy Larry likes this.
  5. Kylekfr1
    Kylekfr1 Member
    Maryland
    1974 ford maverick
    I'll look into the maverick manifold. Is there a way to know exactly what oil filters fit. And yes I definitely have maverick V8 mounts and supports.
    maverick1970 likes this.
  6. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    Has to be something with the mounts. The manifolds could be wrong but the filter can't be.
  7. Kylekfr1
    Kylekfr1 Member
    Maryland
    1974 ford maverick
    Just getting off work but I'll take a pic of the install and post it a little later. Here's the mounts I bought from summit
  8. Krazy Comet
    The std Motorcraft FL1, Fram PH8, etc are supposed to fit without issues... Something isn't right with your motor mounts...
  9. Maverocket
    Northwest
    Those look like Mustang mounts. I believe the Maverick ones are shorter.
  10. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Definitely check your mounts, but you could also use a FL-300 oil filter. It is an inch or two shorter than the FL1.
  11. yellow75
    Tillamook Oregon
    If I recall when mounts are incorrectly installed it moves the motor back about 1", can you show us a pic of how they are installed. Did transmission mount fit correctly ?
  12. Maverocket
    Northwest
    The motor mount part # is for a Mustang, you need a 2316
    Crazy Larry and 71gold like this.
  13. Kylekfr1
    Kylekfr1 Member
    Maryland
    1974 ford maverick
    Here are the pics. looks like new mounts will have to be ordered.
  14. Kylekfr1
    Kylekfr1 Member
    Maryland
    1974 ford maverick
    I'm also converting it over to manual so the transmission crossmember doesn't help.
    I'm also converting to manual transmission so cross member doesn't help. IMAG0547.jpg
  15. Kylekfr1
    Kylekfr1 Member
    Maryland
    1974 ford maverick
    Thanks for all the help. Filter is no longer hitting. Exhaust manifold touching got worst but I'm just gonna pick up a maverick one. IMAG0556.jpg
    71gold and jasonwthompson like this.
