Oil level sensor?
Discussion in 'Technical' started by Jett, Jan 23, 2015.
  1. Jett
    Jett Member
    Los Angeles
    1976 Mercury Comet L6 250 ci
    Hello!
    I've got a small oil leak on the drivers side of my 6cyl block from what I think is the Oil Level Sensor (pic attached just to be sure).
    To resolve that small leak do I need to change that all unit? Just a gasket somewhere? Tighten it even more?
    Thanks in advance for any advice on that matter!
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    That is an oil pressure sending unit. You should replace it, or you can remove, clean, and put some Teflon tape on the threads, reinstall and see if that fixes the leak..
  3. Jett
    Jett Member
    Los Angeles
    thanks for the tip, expecially now I know which part it is haha.
    Next oil change I do I'll try the teflon tape solution.
    Thanks again.
    Cheers!
  4. Krazy Comet
    When there is a leak associated with the oil pressure sender, nine times in ten it's defective...
    Jett and Paul Masson like this.
  5. Paul Masson
    1971 Grabber
    They are also cheap to acquire new replacements. Try www.RockAuto.com They have them anywhere from less than $2 to $20. You shouldn't have to wait to drain the oil to replace it. It only any amount of oil when the engine is running.
  6. Jett
    Jett Member
    Los Angeles
    Ok, I'll look for one then, thanks! You shouldn't have to wait to drain the oil to replace it.
    Not sure I got that part correctly though?
    Does it mean if the engine is not running I can remove it without draining the oil?
    Thanks!
    Paul Masson likes this.
  7. Jett
    Jett Member
    Los Angeles
    Well then I won't take a chance and just go ahead and change it.
  8. Rasit
    Rasit Member
    SE Pennsylvania
    Yes
  9. Jett
    Jett Member
    Los Angeles
    Awesome thanks!
    And last question before I'm good to go, I saw what looks to be the same thing designated as Oil Pressure Switch on some parts sites, same thing right?
    Well, it's a beautiful saturday to keep working on my Comet :)
  10. rthomas771
    Yep, same thing
  11. Jett
    Jett Member
    Los Angeles
    great! Thanks, i'm all good then.
    Cheers!
  12. schroensr
    schroensr knight Runner
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    Welcome to the forum from West Virginia:tiphat:
    Jett likes this.
  13. 71gold
    ...:bouncy:...
  14. Jett
    Jett Member
    Los Angeles
    Thanks! it's a very friendly, welcoming and helpful forum you've got there!!!
  15. Krazy Comet
    Hang around, learn a thing or three & you can say WE have a friendly forum...
    Paul Masson and Jett like this.
