Oil pan for 1972 Maverick......
Discussion in 'Technical' started by doubleoh, Apr 11, 2017.
  1. doubleoh
    doubleoh Member
    Mooresville, NC
    Is there a 6-7 quart oil pan that fits the 302 in my car? Maybe Canton or Moroso?
  2. 71gold
  3. doubleoh
    doubleoh Member
    Mooresville, NC
    Thank you for the welcome. I am getting my "new" '72 Maverick tomorrow, Wednesday the 12th. Can't wait to take it for a ride and then head to my local track (1/8th mile) for some getting aquainted time.
  4. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    You will be limited on pan choices for a Maverick. The problem being that the lower control arm mounts are so close to the pan already they prevent the use of a T style pan. You could go with a deeper pan, just watch your ground clearance, or install an oil cooler and remote mount your oil filter. That would require an additional quart.
  5. dougsharp
    dougsharp Member
    Lake Waukomis MO
    1973 Maverick
    I used a Boss 302 replacement 6 quart pan , works great!
  6. jasonwthompson
    Carrollton TX
    The Boss pan is also what I used, but they are not 6 quart pans. What made them 6 quarts was the addition of the oil cooler.
  7. rlbriggs7212
    rlbriggs7212 Member
    Grass Valley
    1972 Maverick 64 Fairlane 52 Henry J
    I have seen a T style Canton pan on a Mav. All the guy did was notch the back of the sump on either side. I used the Boss 302 copy (also Canton)
