Oil Pressure Sender
Discussion in 'Technical' started by MarulMav, Nov 10, 2005.
  1. MarulMav
    MarulMav Member
    Bellevue, Nebraska
    1975 Maverick (Grabber Clone)
    Got my gauges placed. I need to replace my oil pressure sender with the new one. Problem is it will not fit where the old one is, too big. The old one is located on the drivers side front next to the fuel pump. According to a wiring schematic I have for my 302, it says it's located on the right hand rear corner of engine.:hmmm: Anyone know where I can place the new sender? :confused:
  2. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    See Pic
    This is the only place to my knowledge to have an oil pressure sender
    on a small block Ford.
    You mentioned 'gauges', are you referring to actual gauges or idiot warning
    lights?
    I have both using the brass fittings in the picture. This moves the light
    sender out away from the block-but it would fit without the extension
    allowing me to run a mechanical gauge along with the light.
    This is standard hardware stuff from True Value.
    Seth
  3. MarulMav
    MarulMav Member
    Bellevue, Nebraska
    Reply
    They are actual electronic gauges (don't like idiot lights.) Since they are electronic, can I not just use the original sender? I tried it, but I don't get any reading. The sender that came with the oil gauge is huge!! About the size of the gauge itself.
  4. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    You have to use the sender that came with your aftermarket guage ... idiot light senders won't work ...
  5. MarulMav
    MarulMav Member
    Bellevue, Nebraska
    Got my fittings, elbows, etc. from Ace Hardware this morning. Had to bring the sender up over the fuel pump. Actually looks pretty good (y) . No leaks, everything actually came out perfect. Thanks for the plumbing advise.
  6. das351965
    das351965 Member
    sc
    2-71 mav 1-71 grabber and 75 4dr parts car
    ok guy's what size is the socket that fits the the sending unit for the the idiot light and what size pipe did you use to extent the sending unit to put the gauge with it.as far as lenght and thread size it that make sense. the hardware store is on the way home from work and a 30 min drive back to.so if can give me the sizes I can get it on the way home instead of driving back to it thanks.
  7. littleredtoy
    littleredtoy Seth
    '74 Comet GT
    I have no idea what sizes they are. I took the electric light sending unit with me
    and matched it up.
    Print the pic and take it with you, they should be able to help.
    Seth
  8. Acornridgeman
    Wisconsin
    It is a special size socket, made just for sending units. Just stop in at any auto parts store and ask for a sending unit socket. If you have a friend at any auto repair shop, see if you can borrow one. Another one of those specialty tools that you buy and use a couple times in your life (unless you do repairs for a living).
    Might be regular size socket that works, but I've always used the special one that's made for it.
  9. das351965
    das351965 Member
    sc
    thanks i went and got 1 now to get the plumming for it
