Oil sending unit too big
Discussion in 'General Maverick/Comet' started by randytatum, Oct 12, 2014.
  1. randytatum
    randytatum Member
    mccomb, ms
    I recently bought an autometer electric gauge set to get rid of the mechanical one, the problem im having is the oil sending unit that came with the gauges is wayyyyyy too big to go where the stock one goes... any suggestions????? its a 302
  2. Krazy Comet
    You need a extension, was factory on vehicles with oil pressure gauges... About 6" long with a 45* angle threaded opening at end...
  3. gregmaverick
    gregmaverick Member
    Salem, OR
    1970 maverick
    I'm not sure how much "real estate" you have, between the block/fire-wall/fenders. I used a brass "cross piece" (shaped like a "+". I used a short nipple to connect to the block, used one sender for the Idiot Light, another for the electric fuel pump shut-off, and the third for the electric oil pressure sending unit.
  4. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    You need one of these.
  5. Krazy Comet
  6. bmcdaniel
    bmcdaniel Senile Member
    I just used a brass pipe and a 45* fitting from the hardware store. Cost maybe $3.
    Crazy Larry likes this.
  7. CaptainComet
    Does that new gauge come with a warning light? If not, I would split that off an use both senders so that it would trip the idiot light too. You aren't always looking at the oil pressure gauge ... although the sound of lifters rattling usually gets my attention ...LOL. Been there ... twice .... both times before the idiot light lit up.
