Oil slinger
Discussion in 'Technical' started by jpollard, Feb 10, 2004.
  1. jpollard
    jpollard Member
    Montana
    1977 Factory 302 Mav. 1970 Cougar Eliminator, 1975 302 Grabber, 1976 4door 200...and still looking
    Ok...new question. Is the oil slinger necessary on my rebuilt 77 302? I have heard that many people throw them away and it didnt seem like a good idea to me.
    Also..has anyone ever found a pillar style mount for guages that fit the Mav's???
  2. mavman
    mavman Member
    Arkansas
    you can throw the slinger away if you want. I usually re-use them on street motors, helps keep some of the oil from getting to the front seal, thereby helping reduce the possibility of a leak. Those guage pods....haven't found any that fit the Mav's A-pillar. I just used some universal pods and cleverly hid the wiring behind the brackets and painted the screws. Can't see a thing, and if you're anything like me, it's hard to keep an eye on those guages anyway (I'm right handed and right-eye dominant), especially the boost guage.
    Good luck
  3. courier11sec
    courier11sec Member
    Tucson, AZ
    slinger
    About five minutes after turning the last screw on my motor, I realized I had forgotten the oil slinger and kinda freaked out about it for a couple of minutes. Then I decided too leave it be and see if it was a problem.
    No leaks yet, so I guess I won the gamble.
  4. Thack
    Thack vision advicator
    Moreno Valley Ca
    One of the magazine had this to say about it, If you have an old timing cover that doesn't have a ledge over the seal then you want the slinger. If you have the ledge then you don't need the slinger.
    I personally have not put it on the three engines I have (truck, mustang and maverick) and have no leaks (knock on wood):D
  5. jpollard
    jpollard Member
    Montana
    I will have to check which one I have. The motor is a 77, off hand, should it have a slinger or not. It doesnt sound like it will hurt either way.
    Thanks guys
  6. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    I believe my 77 did not have a slinger.
  7. jpollard
    jpollard Member
    Montana
    hmmmmm....that could be why mine is missing!! :rolleyes:
  8. New2Maverick
    New2Maverick The Newbie Sponge
    Oregon
    1974 Maverick 4 dr, v8 302
    WTF is a slinger?
  9. jpollard
    jpollard Member
    Montana
    :) Its a little tin washer type thingy that slips over the crank shaft between the timing gear and the timing chain cover. It slings oil around to help lube things. Did that make sense?
  10. John A Fasig
    John A Fasig Member
    over here now
    several plastic and tin
    Yep, about .02cents
  11. 71gold
    no ! i think it is a concave washer.it is used to keep the oil off the front seal. it slings the oil that is fed up the crank shaft to the seal back into the block. if it has one leave it on. it can only help. j.m.o....frank...:bananaman :bananaman
  12. Mavaholic
    I had a girl friend once that was an oil slinger. She was kinda fun for awhile. No, wait, different kind of oil. Never mind.
  13. New2Maverick
    Oregon
    So that is what that thing is. I have takend apart lots of motors at work and I always used that as a washer to keep the head bolts from pulling through the chain that I use to pick them up when I go to throw out the bad blocks. :)
