Oil
Discussion in 'General Maverick/Comet' started by SamsDad, Aug 26, 2014.
  1. SamsDad
    SamsDad Member
    Little Rock, Ar
    1973 LDO turned Grabber Clone
    OK, I'm sure I will get many different answers but that is what I want to be honest, it's about time to remove the break in oil (we used Lucas 30w break in oil) and I am trying to determine the best oil for this motor, price is not a factor as I will pay a premium if it is truly going to be what is best for the motor, synthetic or otherwise, I already have the filter I plan on running at every oil change (K & N performance gold HP-3001 wrench off).
    So what oil have some of you used in the same basic set up we have that has gave you longevity? Thanks in advance
  2. 71gold
    the shop that built my 347 recommended...Advance Auto Parts brand motor oil...10w-30...non-synthetic .
  3. SamsDad
    SamsDad Member
    Little Rock, Ar
    OK I appreciate your input
  4. mercgt73
    mercgt73 Member
    We run Federated oil and filters in all our stuff. Get it at our local Fishers.
  5. Dave B
    I run plain old 10w30
  6. John Holden
    John Holden Member
    NJ
    It depends on your bearing clearances among other things.
  7. Bryant
    my engine builder says 20-50 kendal. the viscosity depends on what the engine was built for, so check with your engine builder. i do know that synthetics will have a much higher chance of leaking.
  8. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Valvoline (or any major name-brand) 10w-30. Shouldn't need an additive since it's a roller cam.
    I'd get 10,000 miles on it before running synthetic.
  9. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    I'm running royal purple HPS with mine..has the zinc content for a flat tappet cam.
  10. SamsDad
    SamsDad Member
    Little Rock, Ar
    Although I am running a roller cam I do like the Royal Purple...and even though I don't have to have the zinc, it can't hurt at all, I may just go this route:chirp:
  11. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    They have pretty much the same oil without the "HPS" label and zinc additive for non flat tappet motors I accidentally bought a case and had to return it lol. Watch out for that.. In the store here they stacked it all together!
  12. SamsDad
    SamsDad Member
    Little Rock, Ar
    Thanks, I'll be watching
  13. garrettmuir1227
    garrettmuir1227 (Almost) Certified to Work on Your Porsche
    Temecula,CA
    1974 Mercury Comet (small bumper Mav converted) 2009 Mustang Bullitt #5834
    I've used redline oil and I've ran pennzoil platinum. the pennzoil is made from natural gas and its properties are the best of synthetic and conventional. i currently run it now. highly recommended
  14. Krazy Comet
    10W-30 Shell Rotella...
  15. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    Thinnest oil that'll give you 10spi for every 1k RPMS
    since you got a roller cam, no need to really worry about zinc
    I'd either use Amsoil or that new natural gas oil
    btw, How you liking the new Street demon
    its been a carb I'd actually would feel do slightly better then a properly Q-jet in regard to throttle responce
