ok lets build a 351 w FOR THE STREET
Discussion in 'General Maverick/Comet' started by classic ccg, Feb 3, 2012.
  1. classic ccg
    ringgold GA
    72 maverick
    Ok i got my 351 windsor nad i need lots of help i got some pics here.
    http://mmb.maverick.to/showthread.php?t=83943&page=2
    and i know you guys know your stuff:bowdown:
    i want to make it 393 stroker tell me what you guys would use
    on the heads d80e
    ab if that helps
    thanks for any info
    chris evans
  2. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    Are those the heads you want to go with or are you still looking for a pair of GT40P's?
    They're large chamber heads, which explain the domed pistons. If you're serious about building a 393 stroker, you need to find out what your bore size is and whether or not your block needs any machine work. Your current pistons should be marked .030", .040" or something like that, or maybe they're stock bore. The stroker crank will require 302 pistons of an appropriate size. Flat tops would probably be ok since the increased displacement (stroke) will increase the compression, which is what the domes were for. But that's just a guess until we know your actual ratio. Bore size and the heads you'll use in the final configuration will help us figure that out.
    And then I guess we ought to start talking about cams...
  3. classic ccg
    ringgold GA
    72 maverick
    GT40P's is a yes i need to find some thow i do not see the bore size on the piston and i dont have a guage so i cant tell
  4. classic ccg
    ringgold GA
    72 maverick
    ooh where do i need to go find a good 393 strokerkit or a 408 is there a big difference between 408 and a 393 oh and still going w a t5
  5. facelessnumber
    Memphis, TN
    '71 Grabber
    I doubt there's a big enough difference to justify the cost. With the 393 there's no extra work to be done with the block and it can be done with off the shelf pistons and rods. Tends to be much cheaper. Probably more reliable too, but that's just my opinion.
  6. classic ccg
    ringgold GA
    72 maverick
    cool thank you for your help man:Handshake
  7. Dave B
    Just make it a 427 stroker, if your going to spend the money.
  8. classic ccg
    ringgold GA
    72 maverick
    yep i told my gf and its a no go so im going w a 393
  9. mav1970
    I had my 351C built into a 393 stroker. With my Boss 351 closed chamber heads and using dished reverse dome Keith Black forged pistons, I am still carrying 10 to 1 compression. The 4 bolt main block was bored out .030 over and a Scat stroker crank was used with long Chevy rods. :bouncy:
  10. classic ccg
    ringgold GA
    72 maverick
    wow thnx man so the scat is good
  11. classic ccg
    ringgold GA
    72 maverick
    come on guys no love for the 351?:huh:
  12. bmcdaniel
    bmcdaniel Senile Member
    351 is heavy with large crank main jounals and not many more cid than a much lighter 347.
    I'm I understanding that you want to run P heads on a 393?
  13. troberts289
    troberts289 Member
    Lynden Washington
    1972 Ford Maverick
    If you are serious about putting a tall deck Windsor in your car you there are other things you have to worry about besides just the motor. Since the deck height on the 351 in quite a bit taller the the 302, the 351 will be a very tight squeeze. You are gonna have a hell of a time getting headers in there, and they are gonna be very restrictive since there will be even less room for the headers between the shock towers then the 302 has. A lot of guys do a Mustang II front suspension setup. Which loses the shock towers, and clears up a ton of room to run nice flowing headers.
  14. Nasty72Maverick
    Nasty72Maverick Member
    USA Midwest
    1972 maveric, numerous trucks and harleys
    The greatest of service and parts>http://www.dssracing.com/
  15. classic ccg
    ringgold GA
    72 maverick
    thank you guys im going to shaving the shock towers back and i dont need a 500 hp car just some thing fun to play w and im going to find gt40p
