Okay...A Little Help Please...
Discussion in 'Technical' started by KISSarmy, Aug 13, 2012.
  1. KISSarmy
    KISSarmy Member
    California
    I have a '71 Maverick with a 200 6. What changes and improvements can I make to a stock engine for performance and improved mileage.
    It does have a C4 tranny.
    Any suggestions, I'll look into and see what I can do. Right now, it runs like a clock, but I just want to "spruce" it up a bit.
    Thanks everybody!
  2. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    An electronic ignition is always a good place to start. Headers would be a good mod for performance and mpg's. Rising the compression ratio will also increase power and mileage if you don't mind running higher octane fuel. Also adding a 2bbl would probably help.
  3. Mavman72
    As stated above and...Taller gears (3.50s') and a overdrive trans...
  4. 71gold
    "Right now, it runs like a clock"
    leave it ...as is...you will spend a whole lot of $$$$$ for a...very little gain...:yup:
  5. Earl Branham
    Lugoff, SC
    I second that!!!!! Don't fix it if it ain't broke!!!:thumbs2:
  6. don graham
    :) Or go to classic inlines and see how much it costs.
  7. Zooomzoomguy
    Zooomzoomguy Member
    Detroit, MI
    73 maverick, 2 door
    the only thing that may help you without ruining anything is electronic ignition upgrade...
  8. Del Austin
    Del Austin Member
    Chandler, AZ
    1970 Maverick & 1974 Maverick
    I just converted to Pertronix electronic ignition and a Weber 2 bbl carb from Classic Inlines on my sons car. The car runs much better and gets better mileage. Everything that we did is bolt on so no permanent modifications were made. All the stock parts are labeled and boxed up. Made the car more driveable for my son.
  9. KISSarmy
    KISSarmy Member
    California
    Which electronic ignition kit should I go with?
    Any suggestions for a 2 BBL Carb?
    Dual exhaust suggestions? Make and manufacturer?
    Thanks Fellas, and Gals if you're out there. :tiphat:
  10. Del Austin
    Del Austin Member
    Chandler, AZ
    I went with a pertronix ignitor II kit as I did not want to pull the distributor. The Carb is a Weber 32/36 dgv Carb and planning on putting a header and duals on next. The pertronix stuff can be purchased from autokrafters or just about anywhere. I strongly recommend classic in lines for the rest
