Ooops! moved some stuff around, and look what it did to my stance
Discussion in 'Technical' started by scooper77515, Jun 6, 2005.
  1. scooper77515
    Took the bench seats out, and installed the driver side bucket from a Honda (haven't installed the passenger seat yet). Then put the battery in the trunk on driver side (removed from the front passenger side), and accidentally drilled a hole in my spare tire from right side of trunk, so it is out with a patch in it.
    Now look at my stance! 1" higher in the right rear, 3/4" higher in the right front.
    And it looks worse in real-life...the picture actually corrects the problem a bit.
    I am not sure if the spare tire and passenger bucket will correct the problem. That is approximately 70 lbs removed from the right side, and 50 lbs added to the left (or 120 lbs transferred). It is even worse when I add the 190 lb driver. Any suggestions for evening it up?
    I will install the spare and seat before I make any corrections/adjustments.
  2. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    i used to have a stockcar that leaned like that, we called it Eileen
  3. don graham
    when you put the battery in the trunk you normally put it on the passenger side. i have 2 optima batteries there.:)
  4. scooper77515
    I put the battery in the driver side since I already had the spare tire in on the passenger side. I figured "balance it out" but apparently it is "too balanced", hence, now "Eileen".
    I want to cut the front springs to lower the front end, should cut to match the lean, or cut evenly and move things around to even out the weight distribution?
  5. scooper77515
    After reading some of my postings, I recognize that sometimes, I sound like I know what I am talking about.
    Sometimes, I sound like an idiot.
  6. don graham
    i would plan on cutting them evenly so the distribution is the same on both sides. if not your handling may suffer. put the passenger seat back in and make sure you only have heavy friends.:biglaugh:
  7. scooper77515
    Heavy friends, or heavy wives?
  8. Craig Selvey
    Plus......those rear shackles are not helping anything.
  9. scooper77515
    Those rear shackles are not hurting any, are they?
    They give me about 1" to 1.5" lift, max. The rest is air shocks, at minimum 25psi pressure. I had to get the rear end up a bit so the sidepipes would clear speedbumps (no comments from TL, please).
  10. courier11sec
    courier11sec Member
    Tucson, AZ
    This site is the best place in the world to get razzed about shackles and air shocks. Being a shackle offender myself, and an air shock razzer, I can say that from experience.
  11. don graham
    especially when your cat is a conehead.:biglaugh:
  12. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    How much is Jeg's paying you for that sponsership?
  13. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    I would suggest putting the battery on the passenger side and the spare on the drivers side....if you ever want to go racing, you will/can remove the spare, but you are stuck with the battery :D .
  14. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    I can't comment, huh? man, talk about feeling left out...
  15. blugene
    We are allowed to agree with you, you know? :biglaugh:
    Some times other people can make you feel like an idiot.
    ( I didn't mention your name Hawcko):D
