Opening the bezel
Discussion in 'Audio' started by Wright712, Jul 27, 2009.
  1. Wright712
    Wright712 Member
    I've been using my dremel, but It is looking shabby and taking forever. For those who have successfully dremeled their bezel, what bit is best?
    Thanks,
    Jason
  2. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    Dremel?:huh:
  3. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I used a dremel cutoff disc on mine
  4. Jamie Miles
    Alto, GA
    I've had a few
    I used a dremel with a fiberglass reinforced cut off wheel. Remember the radio will cover the rough edges, so as long as you get a snug fit, it will be fine.
  5. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    x2 :Handshake
  6. rthomas771
    What bezel are you talking about? I used this on a die grinder to open up my radio bezel.
  7. SERE Guy
    SERE Guy Member
    Fairchild AFB, WA
    '73 Mav w/ 302
    Reinforced cutoff wheel on high speed, and a steady hand, then clean it up with a file.
  8. rayzorsharp
    I just took a hammer and made my radio fit my perfect bezel!
    J/K :hide:
    did the same as everyone else, then took a flat file and cleaned the edges up nicely.
  9. darren
    Damn it Ray I just about spit my lunch out.:rofl2:
  10. mojo
    Bezel
    I moved my radio to the trans hump for better access and line of site. I will use the old radio space for a gl flr_refinish_026_original.jpg ove box.
