Opinion on Eastwood
Discussion in 'General Maverick/Comet' started by stockish, Jul 5, 2020.
  1. stockish
    stockish Member
    1973 ford maverick
    Hell everyone looking for opinion on Eastwood products such as there fast etch and rust encapsulator. :huh:
    Thank you
  2. 73curtis
    73curtis Member
    ohio
    I’ve used most of there products , nothing bad to say.
  3. mojo
    I like their rattle can paints; seem to cover better, less spatter better than most I've used and don't get paint all over your fingers at spray tip. They are a little more expensive but worth it to me.
  4. mav1970
    In 2018, I did a quick assembly of a Troyer pavement Modified circle track car that I am restoring - I got it rolling and needed to, at least, paint a door and scotch tape the number to it just for the show - the doors were stripped to bare metal and a coat of Eastwood self etching primer was used - then simple quick rattle can paint was applied - after the show, I went to strip down both doors again and the red came right off but that Eastwood primer was a real bear to remove - I would say it worked 110% great :)
  5. TeeEl
    TeeEl Senior Member
    Colorado
    '73 Ford Maverick Resto-Mod
    I've used 3 of Eastwood's products and was not satisfied with any of them. Their Rust Encapsulator is terrible. POR15 blows it away. I'm not saying that none of their products are good, just the 3 that I used...
  6. Acornridgeman
    Wisconsin
    I have used a lot, and I mean A LOT, of Eastwoods products over the years. Even bought one of their brand named MIG welders.
    I have found all their stuff to be of very high quality and any problems I have had were mostly me either not prepping a surface properly or pushing a product beyond its designed purpose. Some of the products I really liked are the specialty coatings. Silver cad, radiator black, underhood black, anodized finishing, trunk spatters, inner frame coating, any of these specialty coatings are all great. The rust encapsulator is not the best out there. While I have found it good, others like Rust Bullet are better. The encapsulator will not stick to some surfaces as a top coat. On bare metal it was fine.
    Krazy Comet and 73curtis like this.
  7. mav1970
    I have also had great results with Rust Bullet :)
    73curtis likes this.
  8. stockish
    stockish Member
    1973 ford maverick
    Thank you everyone I’m still not sure on what direction I need to go with the rust issue I have. I will post some pictures tomorrow. I don’t want to prep the surface until I got a product in hand so I don’t have to do the area twice.
    Thank you
  9. 73curtis
    73curtis Member
    ohio
    best case with rust is , sandblast , epoxy prime , do any repairs over epoxy ,urethane prime and paint. If that’s not possible clean extremely well (very clean surface) then rust bullet ! a lot better than por 15 . Just my opinion and I’ve done it both ways and good luck with each ,
  10. mvw66gt
    mvw66gt Member
    Arthurdale, West Virginia
    71 Comet GT
    I’ve used their after blast acid etch before priming and it has done a great job. Neutralizes the flash rust.
  11. stockish
    stockish Member
    1973 ford maverick
    Good CE22B137-7561-4121-A959-58FE3F918439.jpeg 2700E33E-FF8F-4BCF-A66D-5A052E3841DA.jpeg E5CB902D-688D-49A5-813E-699D34749BD3.jpeg CE22B137-7561-4121-A959-58FE3F918439.jpeg 2700E33E-FF8F-4BCF-A66D-5A052E3841DA.jpeg E5CB902D-688D-49A5-813E-699D34749BD3.jpeg CE22B137-7561-4121-A959-58FE3F918439.jpeg 2700E33E-FF8F-4BCF-A66D-5A052E3841DA.jpeg E5CB902D-688D-49A5-813E-699D34749BD3.jpeg CE22B137-7561-4121-A959-58FE3F918439.jpeg 2700E33E-FF8F-4BCF-A66D-5A052E3841DA.jpeg E5CB902D-688D-49A5-813E-699D34749BD3.jpeg CE22B137-7561-4121-A959-58FE3F918439.jpeg 2700E33E-FF8F-4BCF-A66D-5A052E3841DA.jpeg E5CB902D-688D-49A5-813E-699D34749BD3.jpeg CE22B137-7561-4121-A959-58FE3F918439.jpeg 2700E33E-FF8F-4BCF-A66D-5A052E3841DA.jpeg E5CB902D-688D-49A5-813E-699D34749BD3.jpeg CE22B137-7561-4121-A959-58FE3F918439.jpeg 2700E33E-FF8F-4BCF-A66D-5A052E3841DA.jpeg E5CB902D-688D-49A5-813E-699D34749BD3.jpeg CE22B137-7561-4121-A959-58FE3F918439.jpeg 2700E33E-FF8F-4BCF-A66D-5A052E3841DA.jpeg E5CB902D-688D-49A5-813E-699D34749BD3.jpeg afternoon this is where my concern is for the most rust. 2700E33E-FF8F-4BCF-A66D-5A052E3841DA.jpeg E5CB902D-688D-49A5-813E-699D34749BD3.jpeg
  12. stockish
    stockish Member
    1973 ford maverick
    Sorry everyone don’t know what I did with that last post with the pictures :rofl2:
  13. Acornridgeman
    Wisconsin
    Great pictures ............ :thumbs2:
    I'll tell you, that is way beyond what Encapsulator can handle - but it will be in the realm of Rust Bullet. Many hours of scraping and a wire brush cup on an angle grinder are in your future .......... :)
    Here are a couple pictures from my past to give you an insight to the power of Rust Bullet. Been 10 years now and the rust never returned.
    Maverick Dude, DGD and stockish like this.
  14. stockish
    stockish Member
    1973 ford maverick
    That looks great!!!! I be been looking at the rust bullet stuff the last few night. So here goes a dumb question ?
    1 So after I clean with a wire brush and grinder.
    2 clean with a pre paint solvent.
    3 what rust bullet product would you use??
    4 would be another rust bullet product??
    5 epoxy primer
    6 body work
  15. TeeEl
    TeeEl Senior Member
    Colorado
    I've never used Rust Bullet. I hear it's very good. I can tell you that the only way POR15 is coming off is if you grind it off with a sander. The Eastwood literally peeled off. Their exhaust manifold paint was terrible too. POR15 makes that as well and it's been awesome...
