Part identification
Discussion in 'Parts Interchange' started by Froggy, Oct 21, 2019.
  1. Froggy
    Froggy Member
    Israel
    Ford maverick 1974
    Does anyone know what this part is, and does it have anything to do with air conditioning?
    Photo is just one i found online, think i'm missing this part.
    Thanks for any type of help :D
  2. yellow75
    Tillamook Oregon
    The part you have circled is a heater control mixing valve and does tie in with your A/C unit
    Froggy likes this.
  3. Krazy Comet
    The valve blocks coolant flow through heater core when A/C is activated.
    A "hot" heater core will reduce effectiveness of A/C.
    Froggy likes this.
  4. Froggy
    Froggy Member
    Israel
    Ford maverick 1974
    Thank you very much!
    Does anyone know of a replacement?
  5. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    You can use one for a 69/70 Mustang. They are smaller and look a little different but do the same thing.
  6. Craig Selvey
    The one you have circled in the above picture is the V-8 version, and can be pretty tough to find.
  7. Froggy
    Froggy Member
    Israel
    Ford maverick 1974
    Well i have an inline 6 engine, didn't think it would matter.
    Since i live in a hot climate i just added a manual valve to the hose, thing is i have these two vacuum lines from the AC switch which i couldn't figure out, guess that matter is solved now :D
    Although getting the right part for it would be nice indeed
    Krazy Comet likes this.
  8. Krazy Comet
    In bygone days, that was how heaters were shut off for summer.
    Unused vacuum lines should be plugged off.
  9. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    This is off a 2000 Ranger, it’s what I’ll be using to turn off the flow of antifreeze to the heater core on my Comet.
