Pcv carb question
Discussion in 'General Maverick/Comet' started by satchelmcqueen, Nov 3, 2019.
  1. satchelmcqueen
    satchelmcqueen Member
    north georgia
    I want to clean up the top of my engine a little bit. As of now i have the pcv hose running to the front full vacuum port on the carb.
    The carb is a summit 600. Its the old holy 4010 design. iirc.
    My question is, on the back of the carb at the base is a port for power brake vacuum which i dont use of course. Can i use this port for the pcv valve? The port is under the blades aand should be manifold vacuum correct? Is there any reason i shouldnt use this?
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Yes, you can absolutely use that port for the PCV valve.
  3. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Yes, Yes, and No.
  4. satchelmcqueen
    north georgia
    Thanks! This will clean up thay 1 ugly hose at least.
