phantom turn signals
Discussion in 'General Maverick/Comet' started by mav302, Dec 10, 2012.
  1. mav302
    mav302 Member
    Baxley,Ga
    1970 ford maverick
    Has anyone ever mounted functional turn signals behind the front grille...my car is a 70..i can already tell original turn signals that mount under the bumoper will be tough to find and id like to do something alil different...just wanted to get.opinions on.how it would look
  2. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Not an original grille but here...[nomedia="http://www.youtube.com/watch?v=QE0Sek-4Ef0"]turn signal.wmv - YouTube[/nomedia]
  3. 71gold
    anything will..."look good"...as long as everyone on here likes it...:rolleyes:
    ...:D...
  4. groberts101
    groberts101 Member
    Minneapolis, MN
    unless it's free.
    err.. wait.. even that doesn't matter around here does it?! :biglaugh:
    I think they look OK if you're into that sort of thing.. but I'd probably look for clear lenses w/ yellow bulbs to help accomplish the "phantom" part a bit better.
  5. predfan2001
    Recently saw a guy that gets bumpers (not a Maverick though) and drills or cuts holes in the and mounts led signals behind a sculpted lens on Restomod cars. If the lenses are clear they are barely visable. On a Maverick it would be something like this.
    Personally I'd find the factory ones. They aren't too expensive with the amber lenses.
  6. predfan2001
    You could use some motorcycle lamps mounts to the gravel shield too as a cheap way out. I recently bought some motorcycle brake/turn signals for my trailer that worked out really good. I think I gave $15 for a set.
