Plug wires with hooker 6901 drivers side?
Discussion in 'Technical' started by ESampson, Jul 1, 2012.
  1. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    I have msd streetfire wires that are the straight ones and the old stock 45 degrees wires I can't seem to get any on the driver side, is there a special one...? Im out in the shop fighting it if anyone has a answer please let me know! Thanks
  2. Mad Goon
    Mad Goon Scaring the Hondas
    Redondo Beach, California
    I used a universal Accel kit and trimmed away some of the plug boot. That, angling your hand the right way with the correct amount of cussing and you should get them on.
  3. Bryant
    these are what i run http://www.summitracing.com/parts/ACC-7054/
    these have a lifetime warranty and summit is really good about honoring the warranty. these were recommended to me by a race team that did a bunch of dyno testing on plug wires and they made the best power.
    they fit my 6901s with out any problems
  4. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    Can't get #6 cyl wire on.. Got them all except this one
  5. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    Pretty expensive but if it has that warranty.. That's great, got a pic of yours installed? I can't believe the difficulty of the driver side, especially #6.. just doesn't make sense.. Guess my plug boots were a 70 dollar waste if I have to switch to 45 degree plugs too eh
  6. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    Anyone else use other types/brands?
  7. Earl Branham
    Lugoff, SC
    I use Taylor 8mm wires, and have had no problems. You're right, #6 is a pita.
  8. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    they a 45* angled wire? do they not melt from sitting on the header?
  9. yellow75
    Tillamook Oregon
    I am using the MSD 8.5 wires with multi angle boots and have had good luck with them. I do like the Accel 300+ though.
    You could always undo the motor mount on the drivers side and lift the engine a little, I also found it is easier if the valve covers are off. If you put a little dielectric grease on the inside of the boots they slide on easier
  10. cody674
    cody674 Member
    1972 Ford Maverick
    now thats how i get it done
  11. Earl Branham
    Lugoff, SC
    Mine don't hit the headers. You have to be very carefull where you place them and loom them up.
  12. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    I'm running Accel straight plug boot wires, they don't hit my 6901 headers anywhere.
  13. Earl Branham
    Lugoff, SC
    Yes, they are 45degree plug ends.
  14. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    Well I tried accel 45* and 90* and just came back with Taylor 135* and tried msd straights.. Closest I got was with the 90s all went on but no way it would go on #6 I tried for 45mins.. As well did my brother
  15. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
