poll - Grabber Hood Scoops - any gasket or sealer?
Discussion in 'Cosmetic' started by Acornridgeman, Jul 4, 2019.
What have you done for Grabber hood scoop sealer?
Poll closed Aug 4, 2019.
  1. Metal to Metal - just like the factory did
    100.0%
  2. Made a thin paper gasket
    0 vote(s)
    0.0%
  3. Made a rubber gasket
    0 vote(s)
    0.0%
  4. Used a body sealer - like 3M rope caulk (dumdum)
    0 vote(s)
    0.0%
  1. Acornridgeman
    Wisconsin
    Curious what everyone has done with the factory Grabber scoops as far as body sealer. I know the factory just put them on metal to metal, but it seems like it would be a good place to have either a thin paper gasket, some u-channel rubber on the hood edge of the scoop hole, or a thin bead of 3M body sealer, rope caulk or dumdum.
    What have you guys done?
  2. rthomas771
    I used the factory style acorn flange palnut w/sealant. I'm sure maybe some of the sealer found its way between the scoop and hood around the studs. Don't know if I should vote #1 or #4 so put me down as #5
