popping under heavy pedal, above 4k rpm
Discussion in 'Technical' started by xpsnake, Jan 20, 2007.
  1. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    Since I built this motor, I have been chasing, a fuel, ignition, timing, or vac. problem.
    When I floor the gas, right about 4,000rpm, the engine starts popping, HARD. If I step into it slow, it won't pop as much, but it almost always starts above 4,000 rpm.
    One person had suggest that I have a manifold leak. Another suggested that the engine is going lean when the secondaries are opening. I also suspected the ignition. It's a used points dizzy with pertronix I in it.
    I have great oil pressure (60 cold/45 hot) and the engine runs around 170-180 degrees degrees in this weather (20-40 degrees).
    306ci
    KB flat top pistons
    eagle i-beam rods
    stock crank
    tfs stage 1 cam (.499/.510 w/1.6's)
    1.7 roller rockers (.538/.542)
    hooker 6901 headers
    e7te heads, shaved ~10:1 comp
    weiand 4011 intake
    holley 600 carb vac 2ndary. #78 jets (primary)
    mechanical fuel pump ('66 GT-500 289 oversize with filter base)
    pertronix in-dizzy ignition
    running ahead of a c4 and 3.00 open rear w/ a 3k stall from edge
  2. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    i had a similar problem once with a 750 vacume carb,i tried a 750 dp carb and it cured it.Then i put the vacume carb on my pick up and it worked fine.,so there was nothing wrong with the carb just the engine didn't like the vacume secondarys.Just something to try.
  3. ShadowMaster
    ShadowMaster The Bad Guy
    The ShadowLands
    1969 1/2 Maverick
    Have you checked the plugs to see if it is going lean? What coil and plug wires do you have?
  4. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I have experienced those problems also Bruce. If you have not replaced the dist cap and rotor, do so. Resistance is a bitch. Plug wires good? I had a 600 holley do the same thing also. I believe you are running to small a carb, and I dont care what anyone else says, when I put a 700 double pumper on mine it really woke it up and runs better than ever. I ran 2 different new 600's on mine for twenty some odd years. Thought I was satisfied with them, until I put the 700 on and realized the motor just needed more cfm. Our motors are nearly identical. You might consider swapping to a larger carb.
    Dan
  5. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Sure sounds lean to me!
    Have you tried a spring that opens the secondary later?
    You don't have your secondary linkage rigged do you?
    (I am sure you know better, but a lot of folks try it anyway)
    These things could account for Derek's problem too.
    If a DP clears it up, then it is running lean for that engine's needs when the secondarys kick in.
    It may have run fine on another engine because that particular engine like the spring on the secondary or had more signal to flow the secondary circuit sooner.
    Dave
  6. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Have to agree,,, lean or low voltage,,spark. make sure you got 12+volts to coil when running. I'm leaning more towards lean fuel.
  7. YellowStangDuan
    YellowStangDuan Member
    Arlington, Texas
    71 Grabber
    Few things to look at....I didn't go look at my Holley book, but isn't that a little big on the jets for a 600? Also, you can try to wire the secondaries shut, so they won't open, and just work the primaries. How about wires/cap rotor, big cap or little, and what shape? Plug condition and gap? And the dist is used, any end play in the top bushing, and how does the gear look? Where is the timing?
  8. ratio411
    ratio411 Member
    Pensacola
    The carb does seem a bit mellow for his combo, but that won't make it lean.
    The 78s up front are a bit big, but they just might be saving him from total melt-down when the rear goes lean...
    The rear doesn't have jets, it has a metering plate.
    They make those in different sizes just like the jets.
    Have you tried a 'richer' metering plate?
    Dave
    Personally I have had very good luck with 650-750 DPs on similar SBFs.
  9. Dan Starnes
    West Central IL
    I ran 78's up front on my 600 too. That carb is now on my cyclone spoiler, 429cj,, that motor likes that carb,, go figure.
    Dan
  10. YellowStangDuan
    Arlington, Texas
    71 Grabber
    You need to re-jet the carb first. I just looked, it should have 66's in it. 78's are not just a little big, but way too big. You probably fouled the plugs, and that's why it misses. Unleaded fuel does not mark plugs very well, so you can't just think they are ok. All of my Holleys are within a couple of sizes from stock. Usually a size smaller, makes for more consistent ET's that way, rich will pick up when the evening cools down. I would still keep the secondaries from opening at all, tune the primaries until they are right, then open the rear up. Check (or replace) the power valve too.
  11. Charlie
    Charlie maverick.to/grabber
    Indianapolis, IN
    1970 Ford Maverick Grabber (Modified)
    accelerator pump working?
    I agree its probably a carb issue. I'm no carb expert but I've had my share of little problems. Most recently I relised I had the incorrect base gasket on my carb, that sure fixed my idling problems (and some other little stuff that was going on) when I corrected that mistake!
  12. ratio411
    ratio411 Member
    Pensacola
    Bad pump will cause a stumble (or worse) off the line.
    Once you reach 4k rpms and have an issue, you are in secondary territory.
    Accel pump only shows when you stab the gas low rpm or come off idle.
    When he stabs the gas at high rpm and it stumbles, he is either does not have enough metering signal to start the secondary circuit, or the secondary jets are too lean. (no jets in this case, metering plate performs that function, but they are available in different sizes like jets)
    One could get a secondary block and use jets out back too. Easy mod.
    Dave
  13. stmanser
    Davenport, Iowa
    sounds to me like you are pinging. if thats the "popping" sound.
    richen it up a bit or mess with the timing
  14. maverickdvm
    maverickdvm Member
    Michigan
    What about checking the spark plugs, maybe a different heat range, checking the gap? You should be able to get an idea of the leanness etc. but looking at the carbon, pits, and such with a magnifying glass.
  15. ratio411
    ratio411 Member
    Pensacola
    Lean pop and ping are 2 different things and are distinct sounding.
    Lean pop is like a muffled backfire, the best I can describe it.
    The best discription of ping I have heard is 'marbles shaking in a tin can'.
