Power Brake swap ... is this all I need?
Discussion in 'Technical' started by dmhines, Jul 7, 2005.
  1. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Gonna be getting a complete Power Disc Setup for my 74 out of a 76 ... Just want to verify I get everything I need for a simple bolt in swap:
    Booster + MC + Spacer
    Power Brake Pedal
    Prop Valve and Lines to MC
    Hard lines from MC to Hoses
    Spindles, Calipers, Backing Plates, Lines, Rotors, Hoses
    Outer Tie Rod ends
    Funky Shock Tower Brace
    I don't need anything from under the dash except the pedal ... correct?
    Thanks ...
  2. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Dan, you are going to need the entire brake pedal/steering column bracket, as it is completely different from the non-power set-up. The power-brake pedal hangs from the left side of the column as opposed to the right side on non-power models...
  3. Mavaholic
    Plus the pivit is angled.
  4. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Indulge me please, guys.
    a) Why would you need a booster? I always thought we could use the same setup - just use a proportioning valve? (hmmm... maybe that's just for when the front brakes are changed to discs)
    b) What's the need for new tie-rod ends? (This one has me stumped)
    c) Why would you need to change the brake pedal (other than to make it look original)?
    Thanks
  5. dmhines
    Cumming, GA
    That sucks ... didn't really want that hassle .... Thanks ...
    Is it true you can pull the support without removing they entire steering column?
  6. dmhines
    Cumming, GA
    a) Only need the booster if you want Power Disc
    b) 75-77 had different tie-rod ends .. I assume for the disc spindles
    c) Like they said above ... everything is different, including the pedal, on Power Disc cars ...
  7. Rick Book
    Rick Book Member
    Thailand
    One more question, what in the heck are we doing up so early? It's 5:23 am. I couldn't sleep. Ha! Always some friends around no matter the time of night or morning.
    I think this interweb thing is gonna catch on.
  8. dmhines
    Cumming, GA
    Good Morning ... 6:23 here in GA .... First I get ready for work ... then I get my son ready for day camp ....
  9. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    I believe you will also have to redrill the holes in the firewall to mount the brake booster. That info was added to my technical article on my website a while back. I think the guy that did it kind of went about doing it the hard way, but it was more apparent that they had to be redrilled than in the original article. Power brake swap
  10. dmhines
    Cumming, GA
    Thanks Matt .. just checked your website .... you just made my life much easier by convincing me that a power disc swap ain't worth the headache .... :) I'll stick with Manual Discs ...
  11. MavMark
    MavMark Mega Modifier
    Detroit Area, Michigan
    Heh...you could always install a Hydroboost power brake system...;) :D
  12. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    as far as the tie rod ends go, just go to your parts store and ask for tie rod ends from whatever your donor car was. (76 mav? 79 granada?... whatever)
  13. Grabber5.0
    Kansas City, MO
    71 Grabber
    I'm still debating whether to do the swap myself when I convert the Grabber over to disc. I am thinking I will convert to manual disc first and see how I like it compared to the power discs I have now.
  14. Mavaholic
    I've driven a maverick with the power disc and I believe the difference is more dramatic than going from drums to disc. When I converted mine from 4 lug to 5 with front disc, I really didnt notice any difference in required pedal pressure to stop my car. The disc definately worked better in that they didnt fade and always pulled straight on hard braking. I would love to add power to my disc but I wouldnt use the factory set up mainly because it is too bulky and secondly because I run manuals. I posted a pictures somewhere that showed a guy in Carlisle that got a booster and master cylinder to fit behind the shock tower.
  15. dmhines
    Cumming, GA
