power brakes
Discussion in 'Parts Interchange' started by rab1969, Jan 23, 2011.
  1. rab1969
    rab1969 Member
    north carolina
    Maverick
    Does anyone know what power brake bracket for the master cylinder will work on a 1973 Maverick 4dr with a 302 2v? My car is currently manual brakes and I want to up grade it so my wife can use it as a back up car (she has never had a car without power brakes or steering) . So I would like to upgrade the brake system. Right now it is still manual drum on all 4
  2. Craig Selvey
    First thing you need to do is convert to disc brakes. This will be about an 80% improvment over drums. Then....if you want to add a power booster to the disc brakes, you can, but in my opinion it is only about 10% improvement over disc brakes.
  3. rayzorsharp
    I agree with Craig on that.
  4. rab1969
    rab1969 Member
    north carolina
    Maverick
    Just wanted to say thanks for all the advice. What rotors, spindles, and calipers do I need to find to convert drums to disc brakes?
  5. mercgt73
    mercgt73 Member
