Power Disc Brakes?
Discussion in 'Parts Interchange' started by Fred Fermin, Aug 28, 2002.
  1. Fred Fermin
    Fred Fermin Member
    Ca
    72 Maverick Grabber
    Hi all,
    I was wonder if a power disc brake set up will bolt into a Maverick? Master cylinder, power booster, brake pedal assembly, etc.?
    thanks,
    Fred Fermin
    72 Grabber 302
  2. Craig Selvey
    If it is a "Maverick" power brake set-up...it will work.
  3. Fred Fermin
    Fred Fermin Member
    Ca
    72 Maverick Grabber
    Granada?
    Will a Granada booster and pedal assembly work?
    Thanks,
    Fred
  4. Craig Selvey
  5. Fred Fermin
    Fred Fermin Member
    Ca
    72 Maverick Grabber
    Thanks
    Thanks for the quick reply Craig...
    Fred
  6. fmontanez1974
    fmontanez1974 New Member
    Los Angeles, CA
    1974 Maverick, 4 door
    Hi Craig,
    I was thinking about doing a disc brake conversion. Are there any aftermarket products that you would recommend?
  7. Craig Selvey
  8. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Craig is right about a direct swap...
    But with some fabbing, folks have gotten many hybrid setups to work.
    The only difference in pedals is the location of the pin that hooks to the brake rod.
    Therefore you can save yourself alot of trouble there by just moving the pin.
    If you don't like or can't find the Maverick power booster, folks have retrofit other very small boosters. They are very thin so that you don't need the huge driver's side tower brace that is with the stock Mav booster.
    Do some checking around, there are threads here, or you can Google for early Mustang/Falcon booster swaps. They need small/thin boosters as well.
    Good luck
    Dave
  9. murphy88
    murphy88 Member
    waterloo on
    73 maverick 76comet
    will spinldles and rotors off a pinto fit a maverick??
  10. Craig Selvey
    Will they FIT.....maybe.
    Will they WORK.....NO. :D
  11. tim keck
    sharps chapel,Tn
    Do you really need POWER brakes on a v8 car?Sure is crowded in there.
  12. lefteyedom
    lefteyedom New Member
    Cheyenne, Wyo
    '72 Maverick
    "Do you really need POWER brakes on a v8 car?Sure is crowded in there"
    If you make it go faster you need to make it stop better. A 4 disk ABS system would be just about perfect, seeing how this 72 maverick v8 is my 16 year old daughter's daily driver.
    My other project is a 66 CJ5..... four drum slowing, we don't even call it braking.
    I am cutting holes in the floor pan to upgrade to Flintstone braking.
    Gary
    Lydia's crewchief
