Power or no Power,,,(steering)
Discussion in 'Parts Interchange' started by AERDAVID, Dec 2, 2011.
  1. AERDAVID
    AERDAVID Member
    Florida
    1971 maverick
    Greetings, I really haven't given it much thought until now but I can't remember the last time I drove a car without power steering. My build has it with leaks at the lines and cylinder so I was considering a power to manual adpt. part, It will be an occasional driver once I put an engine and frontend in it. The frontend will be R&P on an aftermarket M11. Any thoughts?
  2. 302-72-mav
    302-72-mav Member
    sactown CA
    i don't have power steering in my 69.5 302
    not hard for me to turn the wheels ? but i'm 6'7'' 230
  3. rthomas771
    I'd go with a manual steer pitman/centerlink instead of an adapter
  4. AERDAVID
    AERDAVID Member
    Florida
    1971 maverick
    Wont that cause it to steer hard or at least harder than stock manual.
    Guessing cause I havn't tried it. I do remember steering gears (power) without power steered hard. Or would that be the same as the adapter.
    The adpt. is about 125.00, Seems like alot to me. Thanks
  5. Lzoesch
    Lzoesch Levi Zoesch
    Spokane, WA
    I have everything you need as far as a power convert to manual steering. Its not as hard as you would think.
  6. scooper77515
