Power Steering help needed
Discussion in 'Technical' started by MikeG747, Jul 13, 2008.
  1. MikeG747
    MikeG747 Member
    Arkansas
    My power steering has 2 symptoms (74 Grabber). First let me say I have replaced all suspnsion & alot of steering parts.
    Symtoms:
    1. The car will be tracking perfectly straight down the road & then out of nowhere the steering will pull to the left. You correct it & it runs straight again. Then out of nowhere it will pull right.
    2. When you go around a sharp curve the steering won't come back to center on its own. Kinda hard one to explain but in my other Mavs after going around a sharp curve I just sort of loosen my grip on the wheel & it straightens back out.
    New Parts:
    Power Steering Pump
    Control Valve
    I haven't replaced the "Power Cylinder" but it looks pretty new. Can someone tell me which part these symptoms point to. Thanks in advance.(y)
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
  3. MavMark
    MavMark Mega Modifier
    Detroit Area, Michigan
    It sounds like a control valve problem to me too...many years ago I had a similar problem where my Mav wanted to steer itself when you turned it in either direction. I took that thing apart and adjusted it probably 100 times. It turned out that the "new" (rebuilt) control valve I put in was no good...I eventually replaced it with a different one and all was well. :)
  4. Dave B
    I rebuilt mine with a kit from NPD.
