Power Steering Pump Question
Discussion in 'Technical' started by madmav25, Jan 31, 2005.
  1. madmav25
    madmav25 Ryan H
    Arizona
    1974 Maverick 302 V8
    I have a 74 mav 302 and the power steering pump keeps making a loud humming sound. It only makes this noise when the engine is warm and when I press the gas. Is this a common problem? Any help appreciated!
  2. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    I take it that it is full of fluid?
    If so, has it run out before?
    Sounds like you have a bearing going bad in that pump.
    To make sure it is the pump, take a piece of long wood,
    sawed off broom handle etc. have someone rev your engine while
    you hold the high tech wooden tool against the reservoir-
    clear of the drive belt. If you can hear it vibrate in this
    high tech wooden tool when you hold it near your ear, it is surely
    your p/s pump. Replace it.
    You can also test your alternator for bad bearings using this highly
    scientific method.
    Oh, and water pumps have been known to make similar noises.
    Good luck-
    Seth
  3. madmav25
    madmav25 Ryan H
    Arizona
    Its full of fluid and im pretty sure it hasn't ran out of fluid either. I'm pretty sure it is the power steering pump it is pretty loud and the sound is coming directly from the area the pump is located.
  4. 71gold
    mad25,
    the way i check alt., water pump and power steering pump is to remove the belts, one at a time.
    power steering pump makes a "whinning" sound :woohoo1: ...
    water pump makes a "knocking" sound :smash: :smash: :smash:
    alt. makes a "chirpping" sound :coco:
    remember these are "southern" cars so the sound yours makes might sound diff.:biglaugh: :biglaugh: :biglaugh: ...frank...
