Power steering pump rebuild
Discussion in 'Technical' started by tchall10@bellso, Dec 24, 2014.
  1. tchall10@bellso
    tchall10@bellso Member
    Nesbit, Ms near Memphis
    Maverick 1973
    I have a problem trying to rebuild my power steering pump. The fitting that is at the back to the pump where the high pressure hose goes is loose after putting back together. I have try different ways to solve the problem and the schematic that came with the rebuild kit does not help. Any help would be appreciated.
      File size:
      123.6 KB
      File size:
      92 KB
      File size:
      106 KB
      File size:
      137.3 KB
  2. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    If I remember correctly, there are 2 nuts that are used on this. The first nut holds the fitting tight against the housing, the second nut is to hold the p.s. bracket to the fitting.
  3. mercgt73
  4. tchall10@bellso
    Maverick 1973
    You are correct about there being 2 nuts. I found out from a power steering re builder that the fitting that comes from the pump where the high pressure lines connects is suppose to be welded in. Mine broke loose and I order a rebuilt pump and used my existing housing since I had it powder coated. I appreciate the help I received.
