power steering pump
Discussion in 'General Maverick/Comet' started by wolfheads, Mar 27, 2021.
  1. wolfheads
    wolfheads MadMav
    Florida
    73 Maverick / 2000 Harley Low Rider
    Hey guys. I've replaced the power steering pump in my 73 Maverick 3 times. The first two were reman Cordone and eventually started leaking. The one I have now was a new one, (not reman) and now it's leaking. Is there a replacement out there that holds up? My power steering system calls for F type fluid.
  2. Krazy Comet
    I've had a new Lares pump om my Fairlane for approx 1½ years, hasn't leaked.
    Got it from Rockauto.
    Where is it leaking? If it's between the pump body and canister(O ring) that's a easy fix. That does assume the canister isn't warped from prying on it when tightening belt. Front seal isn't a impossible task. I replaced one in pump on my Cobra four years ago, no leaks. If nut that holds canister to pump housing is loose they'll leak.
    wolfheads likes this.
  3. wolfheads
    wolfheads MadMav
    Florida
    That's where I bought mine. It's a Lares. It's leaking where the high pressure line's coming out. I was told it a nylon bushing that's wore out.
  4. Krazy Comet
    Other than internal gasket between pump & back of housing, there's absolutely nothing else back there. Large nut on outside of housing must be tight. If that OK, pull pump, remove canister housing & replace gasket. I believe there's a rubber O ring in mine, I bought pump(s) without housing. Actually I have two, second for Cobra that pump is noisy, yet to change it. Since I bought a pump, original has quieted significantly.
    I can take a pict tomorrow of pump without canister.
  5. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I recently replaced the seals on a leaking pump of mine. I did not want to replace the pump as it was working fine other than the leak, and it was quiet. The seal kit is about $15. You may want to watch this to see what is involved. Not a difficult task at all.
  6. Krazy Comet
    Here's what's inside. This orig Ford pump has rubber coated washer, most seem to have paper washer. I know my Lares had a red paper washer, 99% I added a carb or maybe A/C O ring.
  7. jasonwthompson
    Carrollton TX
    I believe the kit I used had a paper type of seal there. I applied a thin layer of rtv to both sides of the seal.
    wolfheads and Krazy Comet like this.
