power steering pump
Discussion in 'General Maverick/Comet' started by Kutlass, Jan 22, 2009.
  1. Kutlass
    Kutlass Member
    Pasco, FL
    1972 Comet and a 1978 f150
    I found a new power steering pump for my comet on ebay. It looks the same as the one on my inline 6 but the new one says it goes on a 302.
    So are they the same pump just different brackets?
    They look the same. I just wanted to make sure they are before i spend $30.
  2. fastback86
    fastback86 Loose cars and fast women
    FL
    1974 Maverick 351W, 1985 5.0 Mustang coupe, 1996 F150, 2004 Subaru WRX Sti (Don't shoot me, it goes like hell!)
    I think the fitting for the return hose is pointed a different direction, and the pulleys are definitely different. I'm pretty sure you can use a 6 cyl pump on a 302 and vice versa if you have the correct brackets and pulleys but the return fitting may hit the shock tower on the 302 with the 6 cyl pump.
  3. Kutlass
    Kutlass Member
    Pasco, FL
    ya now that i look at that your right. It looks like the return line points forward. I dont think ill have any problem with clreance. But im not sure.
    thanks-kris
